pepelxl
status of the sent email?
Fri Jul 19, 2019 4:45 pm
Is it possible to check the status of the sent email?
Learn the script execution status, example:
/tool e-mail send to=exemple@mail.ru subject="Mikrotik" body=hello
:if (email send....) do=
eworm
Long time Member
Long time Member
Re: status of the sent email?  [SOLVED]
Sat Jul 20, 2019 12:19 am
:if ([ /tool e-mail get last-status ] = "succeeded") do={ ...
But I am not sure if you need a delay between sending and checking for status...
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
pepelxl
Sat Jul 20, 2019 8:03 am
Thanks you.
SiB
Forum Veteran
Forum Veteran
Mon Dec 02, 2019 8:24 pm
With waiting loop until "in-progress" will change.
# Wait until other script in bg end sending e-mail now...
while ([tool e-mail get last-status] = "in-progress") do={delay 1s}
delay 2s
# Now I send my e-mail who has wrong smtp server and reach timeout...
tool e-mail send server=1.1.1.1 subject="WrongSMTP" to=name@domain.tld
local EMailStatus [tool e-mail get last-status]
if ($EMailStatus = "failed") do={put "ERROR"}
if ($EMailStatus = "succeeded") do={put "SUCCESS"}
OR
local ExitDoLoop false
while ($ExitDoLoop = false) do={
  local EMailStatus [tool e-mail get last-status];
  if ($EMailStatus = "in-progress") do={delay 1s; put "."} else={
    set $ExitDoLoop true;
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
I will be at MUMEUROPE Prague on ?? ?? 202?
Users browsing this forum: No registered users and 17 guests
