sergefonkou
string comparaition
Tue Jul 30, 2019 9:31 pm
hi,
please, I don't really understand why this script is not working when making comparaison to switch on sim-slot, it's seems mikrotik don't compare string values !!! Please help ?
:local simlte [/system routerboard sim get value-name=sim-slot]
:if ($PingFailCountLTE >= $FailTreshold) do={
:if ($PingFailCountLTE >= 100) do={
:set PingFailCountLTE 100
:if ( $simlte != "b"){
/system routerboard sim set sim-slot=b;
/log warning " etat du port lte va changer à : $simlte"
delay 60s;
:if ($PingFailCountLTE < $FailTreshold) do={
:if ( $simlte != "a"){
/system routerboard sim set sim-slot=a;
delay 60s;
gbudny
Re: string comparaition
Fri Aug 09, 2019 6:15 pm
Hey,
RouterOS does support String comparison ;)
There are few bugs in the script so maybe that is why it is not working.
Remember to put proper construction of :if statement. There are missing "do=" syntax. proper syntax is :if (sth) do={} else={}
delay command must be followed by ":" so :delay time_in_secs is proper syntax.
Once combining plain text with variable into 1 string put it inside brackets in the following manner: :log info ("test notification number: ".$variable);
I hope it will help a bit ;)
Best Regards
Grzegorz Budny
Jotne
Fri Aug 09, 2019 6:58 pm
You do not need semicolon at end of each line ; , only when multiple commands on same line.
Use this to see what type your variable is.
:put [:typeof $myStr]
It its not string, you can force it to string.
:if ([:tostr $myStr] = "something") do={:put "yes"}
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
Users browsing this forum: No registered users and 4 guests
