flynno
api login issues 6.46beta16
Mon Aug 05, 2019 9:53 pm
6.46beta16 installed on hap mini (smips) using PEAR2\Net\RouterOS; api no longer works to login.
PEAR2\Net\RouterOS\DataFlowException: Invalid username or password supplied. in /var/www/html/PEAR2/Net/RouterOS/Client.php:175
Stack trace: #0 /var/www/html/index.php(71):PEAR2\Net\RouterOS\Client->__construct('192.168.88.1', 'api', 'passwordincleartexthere') #1 {main}
Is there any solution for this issue?
benkhlifahaythem
Re: api login issues 6.46beta16
Tue Aug 13, 2019 4:45 pm
Same issue From V6.45.1
Code: Select all
use PEAR2\Net\RouterOS;
require_once 'PEAR2_Net_RouterOS-1.0.0b6.phar';
try{
$util = new RouterOS\Util($client = new RouterOS\Client('ip','user','pwd'));
} catch (Exception $e) {
die($e);
----OUT PUT-----
PEAR2\Net\RouterOS\DataFlowException: Invalid username or password supplied. in phar://C:/xampp/htdocs/test2/PEAR2_Net_RouterOS-1.0.0b6.phar/PEAR2_Net_RouterOS-1.0.0b6/src/PEAR2/Net/RouterOS/Client.php:175 Stack trace: #0 C:\xampp\htdocs\test2\example.php(8): PEAR2\Net\RouterOS\Client->__construct('ip','user','pwd') #1 {main}
mrz
Tue Aug 13, 2019 4:49 pm
Users browsing this forum: No registered users and 14 guests
