upnort
Scripting output
Tue Aug 20, 2019 10:30 pm
My understanding is script output cannot be viewed directly. Instead the output needs to be sent to the log.
I created a simple script, test.rsc:
:local myVar;
:set myVar "test";
:log info "$myVar";
I uploaded the script with scp. I added the script to the script "repository":
/system script add name=test.rsc policy=read,write
Running /system script print shows no errors and lists the script.
When I run the script there are no error messages and there is nothing in the log.
I can manually type :log info "This is a test" and the text appears in the log.
1. What am I doing incorrectly?
2. Do scripts have to use Windows (CR/LF) line endings?
3. When I type /log print I see two entries because I have disk logging configured. How do I show only memory or disk entries?
Thank you. :)
Jotne
Re: Scripting output
Tue Aug 20, 2019 11:14 pm
Change :log info to :put and you get output on your console and wrap the code in {} and you can run int from command line to test thing out.
So this works fine:
:local myVar
:set myVar "test"
:put "$myVar"
PS ; is not needed, only when multiple commands on same line
You can also skip the set (depending on your code) and do like this:
:local myVar "test"
:put "$myVar"
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
upnort
Tue Aug 20, 2019 11:33 pm
Thank you for replying. I'm still not getting any output. :(
I think the problem might be the script. When I run /system script print the script is tagged as I - Invalid. I'm looking around the web for how to remedy the problem but am not finding clues.
Edit: I found the problem. Puzzled how to fix.
Seems I am uploading the file correctly and setting permissions correctly.
The file appears in /file print.
I run /import test.rsc command and see output of Script file loaded and executed successfully
Next I run /system script edit test.rsc source and there is nothing in the script. I copy and paste the contents and then all is well.
Something seems awry with the way I am creating the script and possibly with how I am uploading and importing.
upnort
Wed Aug 21, 2019 12:27 am
Apparently I misunderstood the /import command. The command has nothing to do with preparing the script. The command is for appending the current configuration.
Users browsing this forum: No registered users and 6 guests
