upnort
Actual file names stored in /file
Thu Aug 22, 2019 12:49 am
How are file names handled in scripting? When I run the following snippet, the messages returned are not the human readable file names but some kind of tokenized file name.
# Filename for wildcard filename search.
:local wildcardFilename ($systemIdentity."-".$systemModel."-".$routerOSVersion."-.*backup|rsc")
:set infoMessage "Attempting to delete previous backups."
:put "$infoMessage"
:log info "$infoMessage"
:foreach backupFile in=[/file find name~"$wildcardFilename"] do={
  :do {
    :set infoMessage "Backup Script: Deleting $backupFile"
    :put "$infoMessage"
    #/file remove $backupFile
    :set infoMessage "Backup Script: Removed $backupFile"
    :put "$infoMessage"
  } on-error={
    :set errorMessage "Backup Script: Error removing $backupFile"
    :log error "$errorMessage"
    :set scriptError true
The output:
Backup Script: Deleting *FD0200FA
Backup Script: Removed *FD0200FA
Backup Script: Deleting *FD020148
Backup Script: Removed *FD020148
Backup Script: Deleting *FD02014F
Backup Script: Removed *FD02014F
Backup Script: Deleting *FD020151
Backup Script: Removed *FD020151
Backup Script: Deleting *FD020152
Backup Script: Removed *FD020152
Backup Script: Deleting *FD020154
Backup Script: Removed *FD020154
Thanks again. :)
SiB
Re: Actual file names stored in /file
Mon Aug 26, 2019 2:33 am
Patch
-:set infoMessage "Backup Script: Deleting $backupFile"
+:set infoMessage ("Backup Script: Deleting ".[/file get $backupFile name])
This "tokenized file name" is UID of element and inside foreach loop you can grab property of every element by using GET function. Sometimes you can discover this property by pressing second time TAB in CLI and sometime just checking if this will give proper syntax.
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL | WebChat: Tokonda
upnort
Re: Actual file names stored in /file  [SOLVED]
Tue Aug 27, 2019 3:51 am
Thank you! :)
Users browsing this forum: No registered users and 7 guests
