CZFan
Trying to download json file via ftp
Sun Aug 25, 2019 11:02 pm
I created 2 scripts, one to download ROS update files from another MT router and another to download a webfig skin json file, both via ftp
The download of the package files work great, but using the exact same command for the json file fails with poll error.
Is there anything special about the skins folder or ftp'ing a json file?
MTCNA, MTCTCE, MTCRE & MTCINE
CZFan
Re: Trying to download json file via ftp
Mon Aug 26, 2019 1:14 pm
To provide more info, below is what works:
:local UpdateFile {"Hap-Lite/ppp-6.44.3-smips.npk";"Hap-Lite/security-6.44.3-smips.npk";"Hap-Lite/tr069-client-6.44.3-smips.npk";"Hap-Lite/wireless-6.44.3-smips.npk";"Hap-Lite/advanced-tools-6.44.3-smips.npk";"Hap-Lite/dhcp-6.44.3-smips.npk";"Hap-Lite/system-6.44.3-smips.npk"}
:local RemoteFTP 10.77.0.10;
:local User FTP-User;
:local Pass FTP-Us3r;
:put "Downloading required update files...";
:foreach i in $UpdateFile do={
:put ("Downloading $i")
/tool fetch address=$RemoteFTP src-path=$i \
user=$User mode=ftp password=$Pass port=2121 \
keep-result=yes;
and below is what does not work, get "poll" error
/tool fetch address=10.77.0.10 src-path=Skin-Tmpl/JC-Skin.json dst-path=skins/JC-Skin.json \
user=FTP-User mode=ftp password=FTP-Us3r port=2121 keep-result=yes;
SiB
Re: Trying to download json file via ftp  [SOLVED]
Mon Aug 26, 2019 2:48 pm
I cannot recreate your problem. Works beetwen two MikroTik 6.44.3 server and 6.45.3 client.
Works when I use CLI:
/tool fetch mode=ftp user=ftp-testt password="*******" address=82.214.*.* src-path=skins/cust1-hd-skin.json dst-path=skins/cust1-hd-skin.json
I must use address who is not use in DNAT, user in full privilage. Even if skins folder is not exist then is create automatic.
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL | WebChat: Tokonda
CZFan
Mon Aug 26, 2019 5:37 pm
@SIB,
Thank you, looks like that "poll" error translates into a permissions problem, tested with admin user and worked.
Users browsing this forum: Google [Bot] and 4 guests
