minoanson
GPS speed to knots[SOLVED]
Fri Aug 30, 2019 5:11 pm
Hi to all,
i am trying to read into the mikrotik the speed of the gps from km/h to knots...
:local speedknots [$speed * 0.5399]
any suggestion?
Jotne
Re: GPS speed to knots
Fri Aug 30, 2019 6:14 pm
It seems that RouterOS does not support decimals
But to do math, you need parentheses.
local speed 10
:put $speed
:local speedknots ($speed * 5)
:put $speedknots
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
eworm
Re: GPS speed to knots  [SOLVED]
Fri Aug 30, 2019 10:23 pm
Hi to all,
any suggestion?
How about this?
  :local speed 10;
  :local speedknots (($speed * 5399 / 10000) . "." . (($speed * 5399 / 10) - ($speed * 5399 / 10000 * 1000)));
  :put $speedknots;
This is ugly, but it works. :lol:
Note that $speedknots is a string, not a number. Your can print it, but you can not use it for more math.
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
Jotne
Sat Aug 31, 2019 10:05 am
Will be solved in ROS 7.......
MikroTik->Splunk
minoanson
Mon Sep 02, 2019 1:57 am
Hi to all,
any suggestion?
How about this?
  :local speed 10;
  :put $speedknots;
thanks man! works perfect :)
Users browsing this forum: No registered users and 4 guests
