mmorelie
RBD52G-5HacD2HnD scripting and reset-configuration
Thu Sep 19, 2019 5:02 pm
I try something that is working on a RB2011 on a RBD52G-5HacD2HnD and is not working. The two devices run on ROuterOS 6.44.5 LTS
i have a default configuration where i download a config file with :
:tool fetch \$urlGetConf\
here is the test configuration :
while ([:len [/interface find]] < 5) do={}
add comment=factory name=factory-dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=factory-dhcp disabled=no interface=ether5 name=factory
add address=192.168.88.1/24 comment=factory interface=ether5 network=192.168.88.0
add address=192.168.88.0/24 comment=factory
The command i use for changing the configuration to the newly downloaded
:system reset-configuration keep-users=yes skip-backup=yes run-after-reset=(\$serialNumber.\".rsc\)
When the router is up after the reboot nothing is working, in winbox i can see the router but it has no ip address and i can't log in to.
Anyone as the same problem ? I realy can't figure out what is going on.
mmorelie
Re: RBD52G-5HacD2HnD scripting and reset-configuration
Fri Sep 20, 2019 3:08 pm
I have made some other tests.
I try RouterOS 6.43.16
RB2011 => OK
RB4011 => OK
RBD52G = NOK
Is there a limitation on th RBD52G for such things ?
mmorelie
Fri Sep 20, 2019 4:09 pm
I think i know why it's not working.
After downloading the configuration file $serialNumber.rsc i do :
:system reset-configuration keep-users=yes skip-backup=yes run-after-reset=(\$serialNumber.\".rsc\")
On RB4011 and RB2011 the router restart and when i login if i do :
/file print
I can see the file $serialNumber.rsc
But on the RBD52G the file is not there so the run-after-reset can't work.
Any clue on why the file disappear ?
mmorelie
Thu Sep 26, 2019 12:04 pm
Here is the solution :
RBD52G has spi flash memory, all files outside flash folder will be deleted during reboot, as they are saved in RAM.
So you need to store all files in flash/
Users browsing this forum: bpwl and 10 guests
