ohara
VB.net API new login procedure
Thu Oct 10, 2019 10:17 pm
Hi, can someone please help me how to modify this piece of VB.Net code to make it compatible with the new API login procedure? I am using ROS 6.45.6 and I can't figure it out. Many thanks.
Code: Select all
Public Function Login(ByVal user As String, ByVal pass As String) As Boolean
Send("/login", True)
Dim hash = Read()(0).Split(New String() {"ret="}, StringSplitOptions.None)(1)
Send("/login")
Send("=name=" + user)
Send("=response=00" + EncodePassword(pass, hash), True)
Dim res = Read()
If (res(0) = "!done") Then Return True Else Return False
End Function
SOURCE: https://wiki.mikrotik.com/wiki/API_in_VB_dot_NET
Login method post-v6.43:
/login
=name=admin
=password=
!done
Now client sends username and password in first message.
Password is sent in plain text.
in case of error, reply contains =message=error message.
In case of successful login client can start to issue commands.
nescafe2002
Long time Member
Long time Member
Re: VB.net API new login procedure  [SOLVED]
Thu Oct 10, 2019 10:24 pm
Try this:
		Send("/login")
		Send("=password=" + pass, True)
(Alternatively, use the tik4net package: viewtopic.php?f=9&t=99954)
ohara
Thu Oct 10, 2019 10:48 pm
Thank you nescafe, that worked. I owe you something!
Code: Select all
Send("/login")
Dim res = Read()
End Function
lucasverolo
Thu Oct 31, 2019 7:18 pm
Hi, I need to know, if you can help me in the new login procedure in version 6.45.7 for vb6 for api. Thank you.
Users browsing this forum: No registered users and 12 guests
