MUM Europe 2020
bigd35
Diabling a DHCP server
Sun Feb 09, 2020 4:34 pm
Hi, I'm still quite new to RouterOS's scripting, can anyone perhaps help to say how I would disable an DHCP server in a script?
Zacharias
Re: Diabling a DHCP server
Mon Feb 10, 2020 6:35 pm
What ? Simply do not configure a DHCP Server...
inteq
Tue Feb 11, 2020 1:15 am
To disable
/ip dhcp-server disable 0
To enable
/ip dhcp-server enable 0
If you have multiple DHCP servers, use /ip dhcp-server print to find the number corresponding to your server.
eworm
Thu Feb 13, 2020 9:45 am
Do not follow that advise! You should never use numerical index in scripts.
Try something like:
/ip dhcp-server disable [ find where comment=.... ]
Change the find to your needs.
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
inteq
Thu Feb 13, 2020 1:31 pm
Any particular reason?
nescafe2002
Long time Member
Long time Member
Thu Feb 13, 2020 3:23 pm
https://wiki.mikrotik.com/wiki/Manual:S ... ter_values
But for most entries with a identifier, you can use the name instead:
/ip dhcp-server disable default
/ip dhcp-server enable default
inteq
Thu Feb 13, 2020 5:08 pm
Thank you. Good info.
Users browsing this forum: No registered users and 13 guests
