flameflower
How to get SrcIP address from PPTP Auth failure log?
Mon Mar 16, 2020 2:02 pm
Hi!
I wrote script to ban users who can't establish L2TP connection.
#Preparing
#/system logging action
#add name=FirewallServicesAuthFailure target=memory
#/system logging
#add action=FirewallServicesAuthFailure topics=l2tp,error
#/ip firewall raw
#add action=drop chain=prerouting src-address-list=FirewallServicesAuthFailure
:foreach line in=[/log find buffer=FirewallServicesAuthFailure] do={:do {:local AuthFailureLog [/log get $line message];
:local StrAddrStart [:find $AuthFailureLog "<"];
:local StrAddrEnd [:find $AuthFailureLog ":"];
:local StrUserStart [:find $AuthFailureLog "user "];
:local StrUserEnd [:find $AuthFailureLog "authentication failed"];
:local StrUser "";
:local StrAddr "";
:local StrAddrLen;
:local PickAddrStartLen "1";
:local PickAddrEndLen;
:local AuthFailureIP;
:local AuthFailureIPBanTimeout "30d";
:set StrAddr [:pick $AuthFailureLog $StrAddrStart $StrAddrEnd];
:set StrUser [:pick $AuthFailureLog $StrUserStart $StrUserEnd];
:set StrAddrLen [:len $StrAddr];
:set PickAddrEndLen ($StrAddrLen-1);
:set AuthFailureIP [:pick $StrAddr $PickAddrStartLen $PickAddrEndLen ];
/ip firewall address-list add list=FirewallServicesAuthFailure address=$AuthFailureIP comment=$StrUser timeout=$AuthFailureIPBanTimeout;
} on-error={};
/system logging action set FirewallServicesAuthFailure memory-lines=1;
/system logging action set FirewallServicesAuthFailure memory-lines=1000;
For L2TP connections it works fine, but it didn't work for PPTP because in <> brackets we have some number instead IP.
Any ideas how to get SRC IP from failed PPTP authentication parsing log files?
nacer
Re: How to get SrcIP address from PPTP Auth failure log?
Wed Jun 17, 2020 2:13 pm
Did you find any solution?
mutluit
Forum Veteran
Forum Veteran
Wed Jun 17, 2020 2:53 pm
The IP is in the previous log line "TCP connection established from ..."
flameflower
Mon Jun 29, 2020 9:33 am
I know it, but in this log we have successful and failed connections.
So if we'll have many simultaneous connections in short time it [scrpit] will ban legitimate connections.
jvanhambelgium
Mon Jun 29, 2020 9:41 am
Is there a certain "pattern" in the source IP's of the failed attempts ?
You could try get these IP's on a access-list if they setup more then 3x / minute to the VPN service
Each of these IP's will go trough the SYN - SYN ACK - ACK TCP-setup states, so you could "watch" for incoming "SYN" packets and if the same IP does this more then 3x / minute to the VPN port chances are big its not normal...
futstars
Sat Jan 23, 2021 2:55 am
working 100% ... great job
is it posible to modifid it for sstp server?
best regard
Users browsing this forum: rsisyphus and 29 guests
