JoshSullivan20
PHP API Login Method Example [Help Please]
Fri Mar 20, 2020 10:09 am
I am trying to login to a MikroTik router using an API, I believe the PHP in the current API is outdated and doesn't match the new login method.
Current code:
When the API is run the following error is displayed in the MikroTik terminal.
system,error,critical login failure for user admin from 192.168.1.198 via API
Would someone be able to provide a working login example via a PHP API?
Thanks!
Last edited by JoshSullivan20 on Sat Mar 21, 2020 6:58 pm, edited 1 time in total.
mrz
Re: PHP API Login Method Example
Fri Mar 20, 2020 10:17 am
send in initial login message
/login
=name=user
=password=xxx
JoshSullivan20
Fri Mar 20, 2020 10:27 am
/login
=name=user
=password=xxx
Thanks for your fast response, however I'm still stuck. Getting the same login failure.
My current login method is:
	function connect($ip, $login, $password) {
		for ($ATTEMPT = 1; $ATTEMPT <= $this->attempts; $ATTEMPT++) {
			$this->connected = false;
			$this->debug('Connection attempt #' . $ATTEMPT . ' to ' . $ip . ':' . $this->port . '...');
			if ($this->socket = @fsockopen($ip, $this->port, $this->error_no, $this->error_str, $this->timeout) ) {
				socket_set_timeout($this->socket, $this->timeout);
				$this->write('/login');
				$this->write('=name=' . $login);
				$this->write('=password=' . $password);
				$RESPONSE = $this->read(false);
				if ($RESPONSE[0] == '!done') {
					$this->connected = true;
					break;
				fclose($this->socket);
			sleep($this->delay);
		if ($this->connected)
			$this->debug('Connected...');
		else
			$this->debug('Error...');
		return $this->connected;
mrz
Fri Mar 20, 2020 10:37 am
I do not know anything about php api, but shouldn't it be like this?
$this->write('/login', false);
$this->write('=name=' . $login, false);
JoshSullivan20
Fri Mar 20, 2020 10:49 am
I'm not to sure on this PHP, I've updated the code like you suggested, same login failure :(
JoshSullivan20
Fri Mar 20, 2020 12:00 pm
Also guys, any reason why this page in unavailable?
https://wiki.mikrotik.com/wiki/API_PHP_class
JoshSullivan20
Fri Mar 20, 2020 6:30 pm
Oh,
JoshSullivan20
Sat Mar 21, 2020 6:52 pm
*bump*
Has anyone got a working PHP API connection?
Please :)
Sob
Re: PHP API Login Method Example [Help Please]
Sun Mar 22, 2020 1:45 am
Are you sure you have correct password, you are connecting to right router, etc? Because your code with mrz's update works.
Excessive quoting is useless and annoying. If you use it, please consider if you could do without it.
JoshSullivan20
Mon Mar 23, 2020 11:18 am
Please could you send me this code that you said works?
Cheers :)
Sob
Re: PHP API Login Method Example [Help Please]  [SOLVED]
Tue Mar 24, 2020 3:48 am
Here it is. It has slightly different formatting, but it's the same code.
JoshSullivan20
Tue Mar 24, 2020 6:17 pm
Thanks for that! It's working now.
(+ it turns out I was editing the wrong API class file as there were multiple for some reason! :P)
lupael
Sun Aug 02, 2020 2:25 am
Getting login failure massage
seanfilipin
Tue Feb 23, 2021 9:44 pm
Thanks mate! I was trying to make the connection work finally, due to your code, it works!
Thank you very much!
Sean.
Users browsing this forum: No registered users and 22 guests
