ik3umt
Enable a rule just for specific time
Sun Mar 22, 2020 6:26 pm
How can I set a timer to trigger a firewall rule enabling and automatically disabling after X minutes ?
Not a scheduled rule (made by schedule or rule "time" option) , a "one shot" rule to be triggered when needed.
msatter
Re: Enable a rule just for specific time
Sun Mar 22, 2020 7:05 pm
You can do that in scheduler with one activating the rule and a second onedisabling it again.
In a scipt you can also put a :delay 2m between to script lines.
Two RB760iGS (hEX S) in series. One does PPPoE and both do IKEv2.
Running:
RouterOS 6.47.beta.x / Winbox 3.21 / MikroTik APP 1.3.12
NordVPN viewtopic.php?f=2&t=158439&p=781009 for multiple connections.
ik3umt
Mon Mar 23, 2020 11:52 am
Thanks,
What about to simply enable the rule and disable it after x minutes ?
/ip firewall filter enable <rule>
delay 3600;
/ip firewall filter disable <rule>
any issue in leaving script hung for a long time ?
Zacharias
Mon Mar 23, 2020 12:33 pm
Obvioulsy it will consume some memory and CPU...
FRANKMUNOZ
Mon Mar 23, 2020 4:12 pm
/system scheduler
add interval=31s name=schedule1 on-event="/ip firewall filter disable 2" policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-time=startup
add interval=14s name=schedule2 on-event="/ip firewall filter enable 2" policy=\
there you have the two scripts, you just have to adapt it to your demands, I hope they serve you.
FRANKMUNOZ
Mon Mar 23, 2020 5:39 pm
/system scheduler
add disabled=yes interval=30s name="Scheduler10" on-event=\
"/ip firewall filter disable 2\r\
\ndelay 10;\r\
\n/ip firewall filter enable 2" policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=dec/01/2018
start-time=00:00:00
there you have another script, you just have to adapt it to your demands, I hope it works for you
Abduljbbar
Wed Mar 25, 2020 12:42 am
Thanks,
delay 3600;
I think now you just inform the rb to do some thing and take a rest for some second and then do other things so it will not spend cpu and ram
this is my opinion
Oh, Allah save my peoples and all in the earth
Users browsing this forum: No registered users and 62 guests
