CBE
Script to collect IPs from the DNS cache on address lists executes just first block of code.
Sat Apr 18, 2020 4:59 am
Hello. The script is creating address lists just for the first block (amazonaws list), even though the DNS cache contains entries for the other domain keywords. Running the code directly from the Scheduler (the Scheluler doesn't run the script if being called as a separate script) on RouterOS 6.45.8 I'll reallly appreciate any help.
###### Use DNS Entrys and add Address to the Firewall Address-list #
:foreach i in=[/ip dns cache all find where (name~"amazonaws") && (type="A") && (data!="240.0.0.1")] do={
 :local tmpAddress [/ip dns cache get $i address];
delay delay-time=3000ms
# prevent script from using all cpu time #
 :if ( [/ip firewall address-list find where address=$tmpAddress] = "") do={
 :local cacheName [/ip dns cache get $i name] ;
 :log info ("added entry: $cacheName $tmpAddress");
 /ip firewall address-list add address=$tmpAddress list=amazonaws-hosts; } }
:foreach i in=[/ip dns cache all find where (name~".bbcollab.com") && (type="A") && (data!="240.0.0.1")] do={
 /ip firewall address-list add address=$tmpAddress list=blackboard-hosts; } }
:foreach i in=[/ip dns cache all find where (name~".bbcollabcloud.com") && (type="A") && (data!="240.0.0.1")] do={
:foreach i in=[/ip dns cache all find where (name~".bbcollab.cloud") && (type="A") && (data!="240.0.0.1")] do={
:foreach i in=[/ip dns cache all find where (name~"whatsapp") && (type="A") && (data!="240.0.0.1")] do={
 /ip firewall address-list add address=$tmpAddress list=whatsapp-hosts; } }
Jotne
Re: Script to collect IPs from the DNS cache on address lists executes just first block of code.
Sun Apr 19, 2020 12:12 am
Not sure what you need help with?
Did you create the script?
Why do not use Splunk to monitor your MikroTik Router(s)? Look at this page in how to set it up.
MikroTik->Splunk
CBE
Mon Apr 20, 2020 8:20 pm
Finally solved. I put each block of code on separate scripts and called them from a scheduler, inserting a delay between each script call. The delay made the difference.
Thanks Jotne for asking.
praise123
Mon Feb 08, 2021 10:07 pm
Please can you send me the step for which you did this? Thanks ahead. :)
esantiago
Thu Feb 25, 2021 5:09 pm
I would like a copy of the updated script. I've been having problems prioritizing traffic for Blackboard Ultra Collaborate.
My email is esantiago@opto.inter.edu
Users browsing this forum: No registered users and 34 guests
