nichky
Forum Veteran
Forum Veteran
ASK [random wifi password generator]
Tue Apr 21, 2020 5:16 am
i'm using script for "random wifi password generator."
i got two scripts. Both of them are working.
if i ll run the script every 10-15 min it does work well.
Problem:
Weekly it doesn't work.
Script sending me same wifi password from the last ran.
i have attached both scripts.
If both SSIDs are good quality signal, most modern devices choose 5GHz for the speed.
viewtopic.php?f=7&t=176537
!) Safe Mode is your friend;
Jotne
Re: ASK [random wifi password generator]
Tue Apr 21, 2020 8:12 am
When I run the script 1.txt from cli, I do get a "random" password every time.
But if you run the script scheduled, it will not be random, since it uses hour/minutes/seconds to make the random, and this will be the same if you set it to run once a week etc.
PS you should post the script using code tags </> like this:
1.txt
:local wifiprofile wifi_security_profile
:local toEmail yourmail@domain.com
:local time [:pick [/system clock get time] 0 2];
:local min [:pick [/system clock get time] 3 5];
:local sec [:pick [/system clock get time] 6 8];
:local char;
:set char ( $char . [ :pick $time 1 ] . [ :pick $time 0 ]);
:local char1;
:set char1 ( $char1 . [ :pick $min 1 ] . [ :pick $min 0 ]);
:local char2;
:set char2 ( $char2 . [ :pick $sec 1 ] . [ :pick $sec 0 ]);
:local arrayalpha ("2","C","h","Y","!","f","j","c","}","q","k",":","(","}","3","Y","T","|","C","v","}","n","8","I","r","4","p","V","6",":","S","V","=","p","Z","T","6",")","l",":","K","b","=","Y","7","X","c","P","@","g","m","U","T","_","g","v","N","j","E","g","f","D","h","!","W","p","U","z","T","S","}","h","M","Y","i","E","c","4","!","Q","(","<","Y","h","@","e","q","7","]","l","R","-","h","S","w","(",">","/","r","=","<","I","&","5","@","!","|","h","p","l","1","Y","U","2","J","R","T","Y","}","=","b","c","$","9","d","e","@","S","6","W","B","Q","$","S","b","p","}","3","m","X","g","8","y","j","h","S","Z","F","@","!","t","}","!","U","j","/","W","5","}","a","g","!","S","S","T","{","7","f","G","W","T","_","/","k","3","+","T","X","p","m","!","e","i","L","]","3","d","G","T","+","@","H","!","Q","k","X","@","P","Q","+","k","f","K","T","S","{","Q","W","S","<","S","z","z","k","V","@","X","{","4","g","t","X","1","h","5","k","T","_","f","i","{","]","(","Y","/","1","j","h","l","]","S","3","b","Y",":","i","T","j","h","T","7","w","g","D","X","g","T","T","i","|","S","R","!","}","D","d","c","h","d","T","l","N",")","V","u","Z","T","}",":","{","S","m","Z","d","}","Z","Z","S","Y","|","_","d","k","v","h","(","7","/","-");
:local new;
:set new ( $new . [ :pick $arrayalpha ($time+$min+$sec) ] . [ :pick $arrayalpha ($time+$sec) ] . [ :pick $arrayalpha ($min+$sec) ] . [ :pick $arrayalpha $sec ] . [ :pick $arrayalpha $char ] . [ :pick $arrayalpha $char1 ] . [ :pick $arrayalpha $char2 ] . [ :pick $arrayalpha ($char+$char1+$char2) ]);
:local arrlengh [:len $arrayalpha];
:put "Our Array Lengh is $arrlengh Your New String is $new";
Try Splunk> to monitor your MikroTik Router(s). How to set it up. :mrgreen:
MikroTik->Splunk
Jotne
Tue Apr 21, 2020 8:26 am
RouterOS does not have a random function. Many has tried to make script to make random text, but all seems to be flawed.
But this should do, since it gets the string from an external site:
/tool fetch url="https://www.random.org/passwords/\?num=1&len=8&format=plain&rnd=new" keep-result=yes dst-path="pass.txt"
:local pass [/file get pass.txt contents]
:put $pass
EDIT
No need to use a file. This should do:
local pass ([/tool fetch url="https://www.random.org/passwords/\?num=1&len=20&format=plain&rnd=new" output=user as-value]->"data")
:put $pass
MikroTik->Splunk
nichky
Forum Veteran
Forum Veteran
Tue Apr 21, 2020 9:28 am
if i'll use the first you edit, it will work weekly?
second part that you have posted.
So far i don't have any particular website that i can put in
Jotne
Tue Apr 21, 2020 11:32 am
You can use both script in my latest post. Only difference is that one writes to file before it sets the variable.
RouterOS needs to have access to internet for this to work, but should be better than using time to generate a random text.
MikroTik->Splunk
nichky
Forum Veteran
Forum Veteran
Tue Apr 21, 2020 12:44 pm
What about 1.text after you have edited, would be fine?
at this point i need some script which will send email and change wifi sec profile
Jotne
Tue Apr 21, 2020 12:57 pm
Do not use. I only changed so that it show up on display.
It is not a random tool, it wil gave same code every time if its run at the same time of day.
Use this one:
:put $pass
MikroTik->Splunk
nichky
Forum Veteran
Forum Veteran
Tue Apr 21, 2020 1:00 pm
Jotne
Tue Apr 21, 2020 2:43 pm
I do not have a wifi device nearby, but this may work:
# Set your wifi profile
:local wifiprofile set_your_profile
# Set your email
:local toEmail my.emai@gmail.com
# Gets a new password
:local new ([/tool fetch url="https://www.random.org/passwords/\?num=1&len=20&format=plain&rnd=new" output=user as-value]->"data")
# Set password to wifi profile
:interface wireless security-profiles set $wifiprofile wpa-pre-shared-key="$new"
:interface wireless security-profiles set $wifiprofile wpa2-pre-shared-key="$new"
# Send email
:tool e-mail send to=$toEmail subject="$[/system identity get name] WiFi Password" body="This Week's Wireless Password Is: $new"
# Write a log line
:log info message="Wifi password for profile $wifiprofile has ben set to $new"
MikroTik->Splunk
nichky
Forum Veteran
Forum Veteran
Tue Apr 21, 2020 2:52 pm
unfortunately..it doesn't work
Jotne
Tue Apr 21, 2020 3:42 pm
It fail and do not run, or does not set password or does not send emai?
MikroTik->Splunk
nichky
Forum Veteran
Forum Veteran
Wed Apr 22, 2020 12:03 am
it doesn't do anything
Jotne
Wed Apr 22, 2020 8:17 am
Cut an past this to terminal of your Router, do you get a password:
:put $new
MikroTik->Splunk
nichky
Forum Veteran
Forum Veteran
Wed Apr 22, 2020 10:17 am
yes im getting pass
Jotne
Wed Apr 22, 2020 11:54 am
Then try
:interface wireless security-profiles print
to get then name of your profile.
Then run after change your_profile to your profile
:interface wireless security-profiles set your_profile wpa2-pre-shared-key="test"
Does this work?
NB I do not have Wifi device so need to take on test at a time.
If all above work try to cut and past this (aftter change to your_profile
:interface wireless security-profiles set your_profile wpa2-pre-shared-key="$new"
MikroTik->Splunk
nichky
Forum Veteran
Forum Veteran
Wed Apr 22, 2020 1:17 pm
Then try
Does this work?
YES it does work,any pass i put will change to test
how can i combine all together?
Jotne
Wed Apr 22, 2020 8:39 pm
I split it up, so I could see what does not work.
If you have more than one line of commands, you need to wrap then in {} or [] to run from terminal. In script this is not needed.
Not work on terminal
:local test 123
:put $test
This work
:local test 123
:put $test
MikroTik->Splunk
nichky
Forum Veteran
Forum Veteran
Thu Apr 23, 2020 2:06 am
i found this one it does work. Any update that you can do on this?
# Set your email
:local toEmail mail@gmail.com
:local pass ([/tool fetch url="https://www.random.org/passwords/\?num= ... in&rnd=new" output=user as-value]->"data")
:put $pass
:interface wireless security-profiles set $wifiprofile wpa-pre-shared-key="$pass"
:interface wireless security-profiles set $wifiprofile wpa2-pre-shared-key="$pass"
# Send email
:tool e-mail send to=$toEmail subject="$[/system identity get name] WiFi Password" body="This Week's Wireless Password Is: $pass"
# Write a log line
:log info message="Wifi password for profile $wifiprofile has ben set to $pass"
Jotne
Thu Apr 23, 2020 8:27 am
Its more or less the same as I wrote above. Use code tags around your script. Select code and click the </> button.
:put $pass
is not needed.
You need to create a schedule for it to run weekly.
MikroTik->Splunk
nichky
Forum Veteran
Forum Veteran
Fri Apr 24, 2020 12:43 am
please give me an example?
:put $pass
is not needed.
nichky
Forum Veteran
Forum Veteran
Sun Apr 26, 2020 1:03 am
Hi Jotne,
can we do some more easy password?
The current one is much complicated..
Jotne
Sun Apr 26, 2020 9:50 am
You could change the
len=20
to
 len=5
in the URL to get a shorter one, or try to find an other web page that you have more control of the password generation.
MikroTik->Splunk
nichky
Forum Veteran
Forum Veteran
Sun Jun 07, 2020 9:06 am
Thanks a lot Jotne does work.well done
nichky
Forum Veteran
Forum Veteran
Sun Jun 28, 2020 9:34 am
Hi Jotne
after a while that script it stoops to work.
Currently it doesn't work at all.
im getting error :
<503 Service Temporarily Unavailable>
Why is so hard to tha script to send out email and change the sec-pass?
even the previous scripts..
Jotne
Sun Jun 28, 2020 9:46 am
I can not explain why a script stops working. Try to run it on the terminal to see what is going on.
Upgrade your RouterOS if you do run an older version.
MikroTik->Splunk
nichky
Forum Veteran
Forum Veteran
Sun Jun 28, 2020 9:57 am
see what im getting...
nichky
Forum Veteran
Forum Veteran
Sun Jun 28, 2020 10:08 am
im using 6.44.6 (long-term)
everything was fine until this morning..is not the version issus for sure
Jotne
Sun Jun 28, 2020 11:33 am
When you past it to terminal, you do wrap it on brackets? { }
your code
If not it will not work.
6.44.6 are getting some old. Oktober 2019. It should work with the script.
MikroTik->Splunk
nichky
Forum Veteran
Forum Veteran
Sun Jun 28, 2020 2:44 pm
even like that im getting:
failure: closing connection: <503 Service Temporarily Unavailable> 104.20.45.7:443 (4)
Jotne
Sun Jun 28, 2020 5:34 pm
Did you try the url in a browser?
It seems that they have added some DDoS protection using java.
DDoS protection by Cloudflare
So it may prevent the download to work from Mikrotik.
Try to find another password site.
MikroTik->Splunk
nichky
Forum Veteran
Forum Veteran
Mon Jun 29, 2020 1:05 am
can we modificate the previous scripts to sent password weekly?
using website it seems like that will work temporary.
Jotne
Mon Jun 29, 2020 9:44 am
Script creating password based on time will never work on RouterOS. Send an request to MikroTik to add a random password generator.
MikroTik->Splunk
nichky
Forum Veteran
Forum Veteran
Sun Jul 26, 2020 10:50 am
Hi Jotne
one thing i found..interesting
When im activating the script by clicking manually the system/script it does work perfectly.
The problem is when i need to do by system/scheduler, then script sending same pasword..always and always.
i have no idea why..it does that?
Jotne
Sun Jul 26, 2020 6:40 pm
If you use the time base password script it will be the same all time.
Did you try this?
viewtopic.php?p=807658
MikroTik->Splunk
nichky
Forum Veteran
Forum Veteran
Mon Jul 27, 2020 12:30 am
how can i combine that in my case?
Jotne
Mon Jul 27, 2020 8:05 am
Some like this?
:local new ([/certificate scep-server otp generate minutes-valid=0 as-value]->"password")
MikroTik->Splunk
nichky
Forum Veteran
Forum Veteran
Mon Jul 27, 2020 9:37 am
but also that pass want to be sent to email
Jotne
Mon Jul 27, 2020 10:30 am
You need to try an test and learn some scripting.
I just give you idea on how to solve it.
your_profile need to be set to an real profile.
MikroTik->Splunk
nichky
Forum Veteran
Forum Veteran
Mon Jul 27, 2020 11:48 am
has been implemented
we will see the result
msatter
Fri Aug 07, 2020 4:01 pm
To avoid the weekly to be the same also add the weeknumber to one of the values.
Or change the runtime of the script by adding the weeknumber to the seconds of the interval time at the end of the script.
:local $weeknumber=(calculate weeknumber[1-52]);
set scriptname interval=(7d - $weeknumber)
Loving my freedom and so, no Twitter, no Facebook/Instagram/WhatsApp, no Apple and no Google/Alphabet, no Amazon/Cloudfront/AWS. However, 'happy' with giving money to Italy.
Running:
RouterOS 7RC4 and 6.49RC / Winbox 3.31 64bits
SvSx10
Tue Aug 18, 2020 11:09 pm
:local wifiprofile "You wireless security-profiles name"
# "len=" in the url it is the number of characters for in the generated password
/tool fetch url="https://www.random.org/passwords/\?num=1&len=10&format=plain&rnd=new" keep-result=yes dst-path="pass.txt"
delay 3
# The last digit before the closing square bracket must be "len=" from url
:local newPassword [put [pick ([/file get [/file find name=pass.txt] contents]) 0 10]];
:interface wireless security-profiles set $wifiprofile wpa-pre-shared-key="$newPassword";
:interface wireless security-profiles set $wifiprofile wpa2-pre-shared-key="$newPassword";
/file remove [find name="pass.txt"];
/log info message="New Wi-Fi Pass = $newPassword"
Jotne
Mon Aug 24, 2020 12:06 pm
Instead of relay on an external service to get password, you can use this solution.
viewtopic.php?f=9&t=164114
MikroTik->Splunk
Users browsing this forum: No registered users and 16 guests
