cumhureren
Neighbor connection with Terminal
Wed May 20, 2020 1:06 pm
Hi there;
i have automation project and i am new at scripting. i wanna connect other device with terminal
in terminal
i used
tool romon mac-telnet mac-adress
user
password
it works but when i entered tis code to script area it doesnt work.
How can i do this?
thanx for your help
floaty
Re: Neighbor connection with Terminal
Wed May 20, 2020 9:32 pm
stunts like that will not work with user/password-authentication (there is no unattended remote-shell usage which needs interaction for authentication - security-reasons)
you need to setup key-authentication between the devices
then you can use ... :
[admin@tikki] > system ssh-exec
<address> --
<command> --
as-value --
output-to-file -- write output to file instead of 'output' variable
port --
routing-table --
src-address --
user --
https://wiki.mikrotik.com/wiki/Use_SSH_ ... key_login)
We know what happens to people who stay in the middle of the road. They get run over.
mutluit
Long time Member
Long time Member
Thu May 21, 2020 12:56 am
@cumhureren, what error message do you get?
floaty
Thu May 21, 2020 6:27 am
the script just fails ...
it's a nice "try just at home example" :shock:
floaty
Thu May 21, 2020 6:33 am
make yourself acquainted with ssh-key authenticaton !
BUT of course you can try ! ... the youngest day ... ? ... is public !
Users browsing this forum: Google [Bot] and 44 guests
