erkexzcx
[Script] Automatically change DNS if Pi-hole is no longer working
Sun May 31, 2020 2:44 pm
I've wrote a script that detects when Pi-Hole is no longer working, and automatically switches to public DNS 1.1.1.2,1.0.0.2.
Disclaimer: I am aware of possibility to set multiple DNS servers, but for Pi-Hole to work you need to set only Pi-Hole IP address.
Use case: Set-up Mikrotik and RPI with Pi-Hole. When RPI goes down, internet will "stop" working for everyone on the LAN, and you don't want it to happen. Add script to Mikrotik that detects when Pi-Hole is no longer resolving queries and switch all DNS settings on Mikrotik to public DNS servers, such as 1.1.1.2,1.0.0.2. Also notify yourself that RPI is down. Second RPI costs money, and brings no benefits rather than high-availability, so this is not an option in this case.
Variant 1 - changes only DNS server for router. Assumes that all devices use router as the only DNS server:
:local currentDNS [/ip dns get server]
:local piholeDNS "192.168.0.50"
:local backupDNS "1.1.1.2,1.0.0.2"
:local testDomain "www.google.com"
:if ($currentDNS = $piholeDNS) do={
    :do {
        :resolve $testDomain server $piholeDNS
    } on-error={
        /ip dns set servers=$backupDNS
} else={
    :do {
        /ip dns set servers=$piholeDNS
    } on-error={}
Variant 2 - changes only DNS server for router + notify yourself when Pi-Hole goes down via Telegram Bot. Assumes that all devices use router as the only DNS server:
:local telegramBotKey "XXXXXXXXX:XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"
:local chatID "XXXXXXXXX"
    :do {
    } on-error={
        /tool fetch "https://api.telegram.org/bot$telegramBotKey/sendmessage?chat_id=$chatID&text=Pi-Hole not working! Changed DNS from $currentDNS to $backupDNS." keep-result=no
} else={
    :do {
        /tool fetch "https://api.telegram.org/bot$telegramBotKey/sendmessage?chat_id=$chatID&text=Pi-Hole is working again. Changed DNS from $currentDNS to $piholeDNS." keep-result=no
    } on-error={}
Variant 3 - changes DNS server for router and for all the networks (IP --> DHCP Server --> Networks). Depending on lease time, DNS will not update instantly for all clients, but allows Pi-Hole to show what uses it:
    :do {
    } on-error={
        /ip dhcp-server network set [find] dns-server=$backupDNS;
} else={
    :do {
        /ip dhcp-server network set [find] dns-server=$piholeDNS;
    } on-error={}
Variant 4 - changes DNS server for router and for all the networks (IP --> DHCP Server --> Networks) + notify yourself when Pi-Hole goes down via Telegram Bot. Depending on lease time, DNS will not update instantly for all clients, but allows Pi-Hole to show what uses it:
    :do {
    } on-error={
} else={
    :do {
    } on-error={}
Usage: Use system --> scheduler --> add. Set interval to 00:00:30, any name and paste script into "On Event:" field. Do not forget to change variable values to match your Pi-Hole IP address.
EDIT: Updated scripts according to suggestions in comments & offered more variants.
Linux <3
jvanhambelgium
Long time Member
Long time Member
Re: [Script] Automatically change DNS if Pi-hole is no longer working
Sun May 31, 2020 3:13 pm
This will not work for all clients that have received their DHCP-lease.
I don't know how many hours of lease-time you provide so these clients don't really benefit from the switchover you make on RouterOS. If their (only) DNS-server fails it is over & out.
Multiple DNS would be a / the only true "redundant solution" for your clients.
EDIT : Ah ok, so your Mikrotik IS already the DNS for your client and you are only forwarding to either Pi-hole (if operational) or some public upstream DNS in case of failure ? Or not ?
Because if your Mikrotik is in the DNS-chain, do you see in the Pi-hole stats the individual clients ? Aren't they all appearing come from 1 client "mikrotik" ?
Jotne
Sun May 31, 2020 6:43 pm
Thanks for the script.
I do see a use for it in my case. I have a DoH server running separately on an MT running 6.47 beta. On my main MT Router i have one DNS point to that DoH MT router. If add a second DNS on main router, that will be used without going trough the DoH server. So I can use the script to test the if the DNS on the DoH router works, if not replace DNS with a working one.
Some tips.
If you do suggest to use local variable. I do not see in your script any reason to use global variable. It will just fill up the variable space.
Noe need for semicolon at the end of the line. Only needed when multiple commands are on the same line.
So:
    :do {
    } on-error={
} else={
    :do {
    } on-error={}
Try Splunk> to monitor your MikroTik Router(s). How to set it up. :mrgreen:
MikroTik->Splunk
Jotne
Sun May 31, 2020 7:15 pm
Here is my version of DoH server not working any more. Thanks again for the idea.
Added logging when things change. I love to log everything (see my signature)
:local DoHDNS "192.168.20.10"
:local backupDNS "8.8.8.8,1.1.1.1"
:if ($currentDNS = $DoHDNS) do={
    :do {
        :resolve $testDomain server $DoHDNS
    } on-error={
		:log info message="DNS_server=$backupDNS"
} else={
    :do {
        /ip dns set servers=$DoHDNS
		:log info message="DNS_server=$DoHDNS"
    } on-error={}
I do run this with an one minute schedule. 00:01:00
MikroTik->Splunk
erkexzcx
Sun May 31, 2020 7:44 pm
Thank you. I updated my initial comment with your suggestions. :)
Linux <3
ladegro
Wed Jul 29, 2020 10:25 am
Thanks a lot for this, exactly what I was looking for and very useful. Even if there is some downtime because of not yet expired lease time, this guarantees it will eventually come back up. So if I'm away from home, the misses doesn't have to worry. Great!
(using it with adGuard by the way but that of course doesn't matter)
TDJ211
Tue Aug 11, 2020 1:05 pm
Oh wow, this is perfect for me!
Im using a local Unbound DNS server for perfomance and like you Ive found the only way to get the Mikrotik to reliably use the local DNS is to set only the one DNS server.
Ive been bitten once before by forgetting to change my DNS when doing server maintenance. Nice to know ill have a backup just in case the server goes down for real.
Dennypr
Tue Aug 11, 2020 8:04 pm
Please help,
Can i change mac address automatically by script on every day?..
Btw thx can any one to help me
Jotne
Tue Aug 18, 2020 11:00 pm
Yes it can be do.
Post it as a new question.
MikroTik->Splunk
hollerauer
Wed Jan 06, 2021 1:52 pm
!! Due to sporadic failures (in my installation) affecting DNS-queries it is NOT advised to use the proposed configuration in PRODUCTIVE environment. This post will be updated after problem is fixed!!
I've wrote a script that detects when Pi-Hole is no longer working, and automatically switches to public DNS 1.1.1.2,1.0.0.2.Disclaimer: I am aware of possibility to set multiple DNS servers, but for Pi-Hole to work you need to set only Pi-Hole IP address.
This script is exactly what I was looking for. I want to share an even more elegant way how to integrate a Pi-Hole in your LAN.
Use case:
  1. Set mikrotik as DNS server for your LAN(-segments)
    /ip dns set allow-remote-requests=yes servers=$YourPrefferedPublicDNSServers$; \
    /ip dhcp-server network set dns-server=$YourMikrotikLANAddress$
  2. Add a NAT rule for each LAN(-segment) to redirect any traffic from LAN(-segment) associated with udp port 53 to Pi-Hole. Comment the rule with "pihole".
    /ip firewall nat add chain=dstnat action=dst-nat to-addresses=$YourPiHoleAddress$ protocol=udp src-address=$YourLANSegment$ dst-address=!$YourPiHoleAddress$ dst-port=53 comment="pihole"
  3. Add script to switch (enable|disable) NAT rule
    :local piholeDNS "$YourPiHoleAddress$"
    :local testDomain "www.example.com"
    :local piholeRulesEnabled [/ip firewall nat print count-only where comment~"pihole" && !disabled]
    if ($piholeRulesEnabled > 0)
    do={ \
    	:do {:resolve $testDomain server=$piholeDNS} \
    	on-error={/ip firewall nat disable [find comment~"pihole"]} \
    else={ \
    	:do { \
    		:resolve $testDomain server=$piholeDNS; \
    		/ip firewall nat enable [find comment~"pihole"] \
    	on-error={} \
  4. Add scheduler to execute script time based
Benefits:
  • All DNS queries (even the ones from clients where you can not change DNS server) are redirected to Pi-Hole
  • Pi-Hole can "see" all LAN clients
  • Fallback if Pi-Hole is down
zilexa
Thu Jan 14, 2021 5:50 pm
Use case:
    Benefits:
Without using the fallback script yet: the NAT rule does not work as expected.
Scenario 1, my working situation without fallback:
Router IP: 192.168.88.1 with IP > DHCP Server > DNS set to 192.168.88.1
IP > DNS is set to 192.168.88.2
My (Ubuntu) Server running PiHole has IP 192.168.88.2. This way, internet works.
Scenario 1-modified to support a fallback (without the actual script yet):
I change IP > DNS to 1.1.1.1 (necessary for the fallback scenario).
I add the NAT rule:
/ip firewall nat add chain=dstnat action=dst-nat to-addresses=192.168.88.2 protocol=udp src-address=192.168.88.0/24 dst-address=!192.168.88.2 dst-port=53 comment="pihole"
Issue 1:
After I add the NAT rule, my clients cannot resolve DNS anymore. Not even when I disconnect/reconnect them.
Issue 2:
Your rule includes dst-address=!$YourPiHoleAddress$ not sure what it means, but doesn't that exclude the server? I still need my server for other things that requires resolving of domains.
I would love for your NAT rule to work though..
EDIT: to get it to work at all, you also need a masquerade rule like this:
[/code]add action=masquerade chain=srcnat src-address=192.168.88.0/24 dst-address-list=192.168.88.2 dst-port=53 protocol=udp[/code]
But still, the server that runs Pi-Hole is now unable to resolve domains. Also, it seems none of my devices work.
As soon as I disable your NAT rule and my masquarade rule, everything works again.
hollerauer
Thu Jan 14, 2021 9:14 pm
You are correct. That's what I meant with $YourFavoritePublicDNSServers$ = e.g. 1.1.1.1, 1.0.0.1, etc.
I add the NAT rule:
Issue 1:
The parameters are set correct. But your use-case is different then mine. In my case the pihole is in another IP-Segment (10.0.0.0/8). If your mikrotik device is your Internet-gateway than it will loop DNS-traffic (udp p53) back to pihole.
You will need a second rule which is placed above your pihole-rule (processed first):
ip firewall nat add chain=dstnat src-address=192.168.88.2 protocol=udp dst-port=53 comment="traffic pihole to www"
Issue 2:
Means if there is DNS traffic directly to your server it is excluded from this rule. You should configure your server to use 127.0.0.1 for DNS.
Not true. there is no need to masquerade or srcnat or redirect. Masquerade is a special version of srcnat designed for traffic from LAN -> www with changing public ip address.
The dstnat rule will take care of redirecting DNS traffic back to device.
It works like this:
  1. device A asks mikrotik (= per DHCP defined DNS server) for Domain "example.com"
  2. mikrotik recieves the request and checks if there is a firewall (nat) rule for it
  3. as there is a rule (pihole), mikrotik asks pihole for Domain "example.com" in the name of device A
  4. pihole answers to mikrotik and asks mikrotik to forward the answer to device A
  5. mikrotik receives the answer and checks if there is a firewall (nat) ruie for it
  6. mikrotik forwards answer of pihole to device A
Please test the additional NAT rule in your setup. If it works for you I'll edit my original post.
LordTMortis
Fri Jan 15, 2021 5:59 pm
Hey,
I've sucessfully used PiHole to improve my ad-situation and have been trying to use some sort of script to have working failsafe in place in case my Pi is not running.
I am not seeing Mikrotik for the first time, but I am quite new to scripting.
However, I am a bit stuck at the moment, as I do not want to change DNS systemwide, I only want to change DNS for clients that use DHCP.
I used following code to have working switch from piholeDNS to backupDNS:
:local piholeDNS "192.168.88.6"
:local backupDNS "8.8.8.8,8.8.4.4"
:local currentDHCPDNS []
:if ([/ping $piholeDNS count=20] =0) do={
        :log info "PiHole server nedostupny, pro DHCP klienty měním DNS server na zalozni."
    } else={
	    :log info "PiHole server dostupny, netreba nic menit."
This code allows my MK to change DNS for my DHCP clients. It's not ideal, as when my Pi comes back online, there is no automatic change from backupDNS to piholeDNS.
What I did at the moment was adding following line into my else statement:
Which works... but the problem is, it works everytime and in my Log i can see that DNS has been changed everytime. This behaviour is not optimal and I would like to make it work only, if the DNS for my DHCP clients is not piholeDNS. This is the place that made me stuck as I found no way to get information about DHCP DNS only.
I tried to make local variable in which I store the value of currentDHCPDNS:
:local currentDHCPDNS [/ip dhcp-server network get [find dns-server]]
That does not work, so I tried:
:local currentDHCPDNS [/ip dhcp-server network get dns-server]
It seems I cannot figure out how to get desired info.
Could you please give me some hint how to extract current value of DHCP DNS?
Thank you very much.
hollerauer
Fri Jan 22, 2021 9:23 am
You can get the number of DHCP server which use pihole as DNS server:
:local currentDHCPDNS [/ip dhcp-server network print count-only where dns-server=$piholeDNS]
and decide based on that:
:if ($currentDHCPDNS = 0) ...
Another solution might be, instead of using a script you could use the netwatch tool.
/tool netwatch add host=$piholeDNS up-script=[/ip dhcp-server network set dns-server=$piholeDNS] down-script=[/ip dhcp-server network set dns-server=$backupDNS]
A major drawback of both methods is, that clients will notice the change first after dhcp lease renew. Depending on lease-time this can be quite a while (default 10m).
zilexa
Fri Jan 29, 2021 1:16 pm
It works like this:
Sorry it really doesn't work:
  • Router on 192.168.88.1
  • I have a server/nas/workstation on 192.168.88.2.
  • No VLANs or other networks configured besides 192.168.88.0/24.
  • IP > DNS: a public DNS server (9.9.9.9) and Allow Remote Requests enabled.
  • IP > DHCP Server > Networks > 192.168.88.0/24 > 192.168.88.1 (the router itself).
  • chain=dstnat protocol=udp src-address=192.168.88.2 dst-port=53
  • dstnat action=dst-nat to-addresses=192.168.88.2 protocol=udp src-address=192.168.88.0/24 dst-address=!192.168.88.2 dst-port=53
The short rule is placed above the long rule. They are at the top of my NAT list, below those two rules I only have a few port forwarding rules (to my server at 192.168.88.2). My Firewall rules are just the default rules. I am on RouterOS 6.48 stable.
zilexa
Fri Jan 29, 2021 6:06 pm
[/code]add action=masquerade chain=srcnat src-address=192.168.88.0/24 dst-address=192.168.88.2 dst-port=53 protocol=udp[/code]
Ok so just as a test I added the masquerade rule, below the 2 rules you gave me:
Now it works BUT Pihole sees all requests coming from my router. No statistics per client unfortunately.
Without this masquerade rule, no client can resolve domains unfortunately.
As soon as I disable the masquerade rule, it does not work anymore :(
Ddram
Tue Feb 09, 2021 5:38 pm
I also had some problems here. My Pi-Hole is configured with unbound on Port 5335 to resolve from DNS-Rootservers.
The solution that works for me comes from another thread here: viewtopic.php?f=9&t=170487 and i changed some things according to my setup and some overthinking i've done.
Mysetup is:
RB2011iL: 192.168.0.1 configured with two external DNS Servers (1.1.1.1, 1.0.0.1)
Pi-Hole: 192.168.0.250
DHCP-Range: 192.168.0.0/24 and Pi-Hole as DNS
I added two NAT-Rules to grab every dns request and force it to use my configured server.
6 X  ;;; Mikrotik forced
      chain=dstnat action=dst-nat to-addresses=192.168.0.1
      protocol=udp src-address=!192.168.0.1
      dst-address=!192.168.0.1 in-interface=bridge dst-port=53
      log=no log-prefix=""
 7    ;;; pihole forced
      chain=dstnat action=dst-nat to-addresses=192.168.0.250
      protocol=udp src-address=!192.168.0.250
      dst-address=!192.168.0.250 in-interface=bridge
      dst-port=53 log=no log-prefix=""
To check pi-hole running state i have configured a scheduler task that resolves google.com every 5 minutes via pihole. If there's an error the pihole NAT-Rule would be disabled and the mikrotik would be enabled.
:local piholedown [/ip firewall nat get value-name=disabled [find comment="pihole forced"]]
:local piholeDNS "192.168.0.250"
:if ($piholedown = false) do={
    :do {
    } on-error={
		/ip firewall nat;
			disable [find comment="pihole forced"];
			enable [find comment="Mikrotik forced"];
} else={
    :do {
        :resolve $testDomain server $piholeDNS;
		/ip firewall nat;
			enable [find comment="pihole forced"];
			disable [find comment="Mikrotik forced"];
    } on-error={}
In short the pi is my standard and only in case of error there is a forced dns redirection to the router with the external dns servers.
Maybe you could give it a try. (hopefully a successfull one)
As mentioned before, the initial idea came from this thread viewtopic.php?f=9&t=170487
Have a nice day!
PS: English is not my native language, so be careful while reading, it could be nonsense :)
zilexa
Fri Feb 12, 2021 11:13 am
Mysetup is:
 7    ;;; pihole forced
    :do {
    } on-error={
		/ip firewall nat;
} else={
    :do {
		/ip firewall nat;
    } on-error={}
Have a nice day!
@Ddram thank you for posting this. Could you please confirm a few things?
1. the RouterOS version you are using
2. you only have 1 subnet/dhcp range right? So your pihole and your LAN clients are all in the same IP range.
3. In PiHole, do you see DNS requests and nice stats per client? Or does this solution mean PiHole will "see" all DNS requests coming from your router? Because I really want to be able to have per-client stats and I believe your solution works, but in PiHole it will look like you only have 1 client because all requests come from the router?
Ddram
Fri Feb 12, 2021 7:44 pm
Hi zilexa,
1. I'm on Version 6.48
2. Yes that's my small home setup only one subnet with everything in it.
3. Yes, i've read your previous postings and that's exactly what i want and have! ;) Every client calls the Pi with it's own fqdn. As an example, i can see my Mobilephone querying as "OnePlus7T.home.arpa" in pihole querys.
I think the Problem is the srcnat masquerading rule (someone mentioned this before).
With masquerading, every request seems top be sent from your Router. That's the opposit from what you want.
Greetings
zilexa
Sun Feb 14, 2021 1:31 am
Hi zilexa,
Greetings
My point is, it should be impossible without the masquerade rule.
None of my clients are able to access any domains, with only the single rule you mention to force DNS to your pihole.
Are you using the default Firewall rules from 6.48? Do you have other NAT rules set up?
I asked this in a Dutch forum and they confirm it cannot work without the masquerade rule.
Ddram
Sun Feb 14, 2021 2:58 pm
well I see it working every day since exactly one week ago.
Yes I have other nat rules active but none of them handles DNS traffic.
I split my rule with some explanation, maybe someone can correct me, where I'm wrong (or right).
Do
chain=dstnat (declare outgoing nat)
action=dst-nat (redirect for outgoing NAT)
to-addresses=192.168.0.250 (redirect to my pi)
to-ports=53 (to DNS port)
But only if:
protocol=udp (maybe TCP but mostly DNS is a udp thing)
And
src-address=!192.168.0.250 (not from pi, so requests from pi could passthrough)
And
dst-address=!192.168.0.250 (no requests already sent to my pi)
And
in-interface=bridge (request is from local network)
And
dst-port=53 (if DNS port is used)
So every matching request is redirected to the pi. I can use 'ping' and 'dig' commands from my pi (via SSH) as much as I want, everything works as expected.
Maybe I'm wrong, but it's working.
Have a nice Sunday
zilexa
Mon Feb 15, 2021 12:23 pm
Have a nice Sunday
Would you mind posting the output of:
/ip firewall export
You can ofcourse remove all port forwarding rules of NAT.
In my case, I only use the default Mikrotik/RouterOS firewall rules:
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=dst-nat chain=dstnat comment=DNS-to-server-rule1 dst-address=!192.168.88.2 dst-port=53 in-interface=bridge protocol=udp src-address=!192.168.88.2 to-addresses=192.168.88.2 to-ports=53
add action=masquerade chain=srcnat comment=DNS-to-server-rule2 dst-address=192.168.88.2 dst-port=53 protocol=udp src-address=192.168.88.0/24
add action=masquerade chain=srcnat out-interface=pppoe-client
NAT only contains the 2 rules to force DNS to pihole. The very last rule is required for internet access as my proivider uses PPOE.
Ddram
Mon Feb 15, 2021 1:00 pm
Here is my Firewall export, without lists and mangle rules.
add action=drop chain=input comment="Winbox on WAN" dst-port=\
    8291 in-interface=pppoe-out1 log-prefix="winbox on wan " \
    protocol=tcp
    "Drop incoming packets that are not NATted" \
    connection-nat-state=!dstnat connection-state=new \
    in-interface=pppoe-out1 log=yes log-prefix=!NAT
add action=drop chain=forward comment=" Drop  Invalid" \
    connection-state=invalid log-prefix=invalid
    "Drop incoming from internet which is not public IP" \
    in-interface=pppoe-out1 log=yes log-prefix=!public \
    src-address-list=not_in_internet
add action=drop chain=input comment="Drop Wan2Lan DNS (TCP)" \
    dst-port=53 in-interface=pppoe-out1 protocol=tcp
add action=drop chain=input comment="Drop Wan2Lan DNS (UDP)" \
    dst-port=53 in-interface=pppoe-out1 protocol=udp
    "Drop packets from LAN that do not have LAN IP" \
    in-interface=bridge log=yes log-prefix=LAN_!LAN \
    src-address=!192.168.0.0/24
add action=drop chain=forward comment="Firehol list" \
    connection-state=new disabled=yes dst-address-list=firehol
    "Allow established, related" \
add action=accept chain=input comment="Allow internal" \
    src-address-list=allowed_to_router
add action=fasttrack-connection chain=forward comment=\
    "FastTrack" connection-state=\
    established,related
add action=accept chain=forward comment="Established,  Related" \
    "Forward Portmapping (Plex)" connection-nat-state=dstnat \
    dst-port=32400 in-interface=pppoe-out1 log=yes log-prefix=\
    "Forward Plex" protocol=tcp
add action=accept chain=forward comment="SIP forward" \
    connection-nat-state=dstnat log=yes log-prefix=SIP \
    src-address-list=SIP
add action=accept chain=forward comment="Zyxel Forward Rule" \
    dst-address=192.168.1.1 in-interface=bridge log=yes \
    log-prefix="Forward to Zyxel" out-interface=ether1 \
    " Drop  tries  to  reach  not public  addresses  from  LAN" \
    dst-address-list=not_in_internet in-interface=bridge \
    log-prefix=!publich_from_LAN out-interface=!bridge
add action=drop chain=input comment="Drop everything" \
    in-interface=pppoe-out1 log-prefix=dropped
and the NAT part:
add action=dst-nat chain=dstnat comment=\
    "SIP Connection forward 3478 to FB7590 (UDP)" \
    connection-type=sip dst-port=3478 in-interface=pppoe-out1 \
    log=yes log-prefix="UDP(5060)" protocol=udp \
    src-address-list=SIP to-addresses=192.168.0.254 to-ports=\
    3478
    "SIP Connection forward 5060 to FB7590 (UDP)" \
    connection-type=sip dst-port=5060 in-interface=pppoe-out1 \
    5060
    "SIP Connection forward 5060 to FB7590 (TCP)" dst-port=5060 \
    in-interface=pppoe-out1 log=yes log-prefix="TCP(5060)" \
    protocol=tcp src-address-list=SIP to-addresses=\
    192.168.0.254 to-ports=5060
    "SIP forward to FB7590 only 1and1-IPs" in-interface=\
    pppoe-out1 log=yes log-prefix="UDP(CALL)" protocol=udp \
    7077-7110
add action=dst-nat chain=dstnat comment="Plex forward to 32400" \
    dst-port=24179 in-interface=pppoe-out1 log=yes log-prefix=\
    Plex protocol=tcp to-addresses=192.168.0.31 to-ports=32400
add action=dst-nat chain=dstnat comment="PS4 Forward" disabled=\
    yes dst-port=3074 in-interface=pppoe-out1 protocol=udp \
    to-addresses=192.168.0.18 to-ports=3074
add action=dst-nat chain=dstnat comment="Mikrotik forced" \
    disabled=yes dst-address=!192.168.0.1 dst-port=53 \
    in-interface=bridge protocol=udp src-address=!192.168.0.1 \
add action=dst-nat chain=dstnat comment="pihole forced" \
    dst-address=!192.168.0.250 dst-port=53 in-interface=bridge \
    protocol=udp src-address=!192.168.0.250 to-addresses=\
    192.168.0.250 to-ports=53
add action=masquerade chain=srcnat comment=\
    "Outbound to Zyxel for Configuration" dst-address=\
    192.168.1.1 out-interface=ether1
    "Outgoing NAT for WAN" dst-address-list=!not_in_internet \
    out-interface=pppoe-out1
I hope there's something that could help, but i don't see anything related. Maybe there's some difference in your other dns related configuration (pihole or router)?
Here is mine from the router :
set allow-remote-requests=yes cache-max-ttl=12h servers=1.1.1.1,1.0.0.1
How is your pihole configuration?
Greetings
Ddram
Mon Feb 15, 2021 8:48 pm
Hello again,
I did some testing and reconfiguration on my setup, because I was interested, what's wrong on your site.
Guess what happened? Well it doesn't work anymore...
Never touch a running system, I guess....
So I think I was wrong all the time. Maybe someone with more networking experience finds a way.
Until then I will use the solution from the thread I've posted, because it's not DHCP TTL dependent.
Have a nice evening.
shafiqrahman
Thu May 06, 2021 1:37 pm
These are the command that are added:
add address=192.168.88.0/24 dns-server=192.168.88.5 gateway=192.168.88.1 netmask=24
add address=192.168.88.5/32 dns-server=192.168.88.1 gateway=192.168.88.1 netmask=24
For fallback I modified the script and need some help, whether its written in right order or wrong. I am confused about this line
 [/ip dhcp-server network address=192.168.88.0/24 comment=defconf get dns-server]
, and the script formatting. This line doesn't worked for me
]. How do I get dns server status from dhcp server network?
where dns-server
probably cause issue because I have another entry which has 192.168.88.5 as address in dhcp networks.
:local currentDNS [/ip dhcp-server network address=192.168.88.0/24  comment=defconf get dns-server]
:local piholeDNS "192.168.88.5"
    :do {
    } on-error={
        /ip dhcp-server network set 0 address=192.168.88.0/24 dns-server=$piholeDNS comment=defconf dns-none=yes gateway=192.168.88.1 netmask=24
} else={
    :do {
        /ip dhcp-server network set 0 address=192.168.88.0/24 dns-server=$piholeDNS comment=defconf gateway=192.168.88.1 netmask=24
    } on-error={}
Any help will be very much helpful.
zilexa
Wed Jun 30, 2021 12:39 am
The definitive version, in case anyone is searching for it. Note most scripts above lack a space or two, making them incorrect.
With the below, you will get the following:
1. ALWAYS force dns requests to go either via your server (AdGuard Home or PiHole or Unbound etc) OR the public fallback DNS servers configured in your router (blocking Amazon devices, Google devices, smartTVs using their own dns server for tracking & ads).
HOW-TO:
1. in IP > DHCP Server > Networks, set DNS to the same address as the router: 192.168.88.1
2. In IP > DNS set your preferred fallback DNS servers, for example AdGuard DNS: 94.140.14.14 and 94.140.14.15.
3. In IP > Firewall > NAT: the first 2 firewall rules are required to force your server DNS, the 3rd rule is required to force the DNS servers that are configured in IP / DNS:
add action=dst-nat chain=dstnat comment=force-own-DNS1 dst-address=!192.168.88.2 dst-port=53 in-interface=bridge protocol=udp src-address=!192.168.88.2 to-addresses=192.168.88.2 to-ports=53
add action=masquerade chain=srcnat comment=force-own-DNS2 dst-address=192.168.88.2 dst-port=53 protocol=udp src-address=192.168.88.0/24
chain=dstnat action=dst-nat comment=force-router-DNS to-addresses=192.168.88.1 protocol=udp src-address=!192.168.88.1 dst-address=!192.168.88.1 in-interface=bridge dst-port=53
Finally, in System > Scripts, create the following script with name: DNS-fallback.
:local serverIP "192.168.88.2"
:do {
     :resolve $testDomain server $serverIP
      /ip firewall nat;
          enable [find comment="force-own-DNS1"];
          enable [find comment="force-own-DNS2"];
          disable [find comment="force-router-DNS"];
    } on-error={
                /ip firewall nat;
                    enable [find comment="force-router-DNS"];
                    disable [find comment="Force-own-DNS1"];
                    disable [find comment="Force-own-DNS2"];
In System > Scheduler: add a new one, use the name of your script (DNS-fallback) and set interval to 10 seconds (to test).
Go to IP > Firewall > NAT, disable the 2 'force-own-DNS' rules, enable the 'force-router-DNS' rule, wait max 10 seconds. If your server is up and running, the 2 rules should be enabled and the third rule disabled.
Go back to scheduler and change the interval to 1:00 (every minute, should be enough).
Remaining issue: since we need a masquerade rule, we cannot see clients in AdGuard Home or PiHole. Which means you cannot disable blocking per client or set rules per client :(
To solve this, I understand your server should be in a different subnet (IP > DHCP Server > Networks). I tried creating a seperate subnet, changed the static lease of the server IP to reflect the change, refreshed my server network connection etc. But I didn't have internet access, couldn't access the router from the server. Or the clients couldn't access anything on the server.
If anyone has NOOB instructions how to solve this, please share!
Ddram
Wed Jun 30, 2021 8:54 pm
Hi zilexa,
I've found another Thread, started by shafiqrahman at viewtopic.php?p=858144 .
It took me about 2 hours today, to get a second pihole running, with this configuration, for testing purpose. i used information from post #5 and #20, except the part with upnp.
I keep it running until the weekend, and if everything works well, i will move my normal setup (pihole with huge filterlists and unbound) into the second subnet. Until now everything seems to works as we want it to, especially that part with clientnames.
If you have any problems i will try to help you ( maybe this time with some success ;))
greetings
shafiqrahman
Wed Jun 30, 2021 10:56 pm
@Ddram,
Will you please share the unbound functionality or usage here? To my understanding unbound kinda unnecessary because mikrotik already act as a dns cache. If not I am interested too. Also, please let us know your test result with the new setup. Any update/issue will be highly appreciated. :D
Ddram
Thu Jul 01, 2021 8:57 pm
@shafiqrahman,
thanks for your work in the other thread, and all the contributors there. You've achived what many people are searching for ( noobs like me of course :) ).
One day i found pihole for ad/tracker/phishing/malware blocking and there was a tutorial for using unbound as local dns-resolver and caching the root-dns-zone ( it's called "hyperlocal" ), so i gave it a try. Basically i liked the idea to query on a direct way and not be dependend from ISP, Google or Quad9 etc. - dns servers. Another point was that unbound does some cache refresh for often requested domains, so there is a little speedup.
Just for clarification, i'm a noob with about 20 years of experience and it's mostly a thing of "I do it, because i can and maybe i'm learning something new". My actual plan is to keep pihole/unbound running and have the mikrotik dns as failover.
Until now (about 28hours) everything works very well. The alternativ subnet was the solution (i guess it was mentioned in other posts, but i couldn't figure out how to do).
Greetz :)
shafiqrahman
Fri Jul 02, 2021 3:55 am
viewtopic.php?f=13&t=175322&p=858329#p858329
This link might help you. Basically, all ethernet ports are attached to a bridge. You detach your desired ethernet port from that bridge. Make a DHCP server for that port,add ip addresses and define ip pool. Also there is a video on YouTube by Tksja , https://youtu.be/6G6dWF1nipY
Here is the break down of subnet creation:
Remove the desired port from the default bridge(for my case its ether5):
/interface bridge port remove [find interface="ether5"]
This portion is firewall dependent, my firewall requires that it should be in "LAN"
/interface list member add interface=ether5 list=LAN
Now, Give Ip address to that ethernet port.
add address=192.168.188.1/24 comment=pinet interface=ether5 network=192.168.188.0
Assign an IP range for the subnet.
add name=pinet ranges=192.168.188.20-192.168.188.40
Add a dhcp server for that newly created subnet and dhcp server network.
add address-pool=pinet disabled=no interface=ether5 name=pinetDHCP
add address=192.168.188.0/24 comment=pinet gateway=192.168.188.1 netmask=24
If you need more clarification or help, please post on the above mentioned thread, there are other more advance/experienced members who might help :D
Ddram
Sun Jul 04, 2021 3:46 pm
everything is fine. It's running since wednesday and i switched my original pihole setup to the second subnet yesterday.
There was a little problem, because you have to run "pihole -r" to reconfigure the pi with the new ip and gateway. The problem is, that something is messed up with this routine. The gateway doesn't change. I had to open "/etc /dhcpcd.conf" and there where both configurations. I deleted the old one, did a reboot and now everything works as expected.
In the pihole adminpage i had to keep my original subnet and gateway to have nameresolution for my clients.
In short:
Pihole is in 192.168.3.0/24 with 192.168.3.1 as gateway
My clients are in 192.168.0.0/24 and get recognized from the pi
Thanks again :)
shafiqrahman
Sun Jul 04, 2021 9:09 pm
I use pihole inside a container. But, glad it worked for you.
teonok
Thu Jul 29, 2021 11:19 am
When you put pithole server on different subnet what changes you make on firewall rules?
shafiqrahman
Thu Jul 29, 2021 11:27 am
eb123456
Sat Aug 14, 2021 7:42 pm
This seems to resolve against the mikrotik cache, therefore introducing a delay in detection of a pihole outage.
How do we skip the cache for this particular request?
shafiqrahman
Sat Aug 14, 2021 10:02 pm
Most probably not. Not sure about that, but it worked perfectly for me. Try disabling your wan port and see what happens.
eb123456
Sun Aug 15, 2021 10:04 pm
what do you mean
most probably not
pe1chl
Sun Aug 15, 2021 10:49 pm
Actually, when you want to do things like this you should look at the possibilities of "IP anycast routing".
You can add another IP address to the Pi (it would be possible without that but it would have some disadvantages) and then you can add a route to that address with "ping" check enabled. So the route will disappear as soon as the ping fails.
Then, you also add another route to the same address with a greater distance to the alternative you want to use for the service. In this case it would be a route via the default gateway.
And, you in this case also need to setup a dst-nat to map that address to the DNS service you want to use instead (e.g. 1.1.1.1)
Now, your DNS settings are set to the anycast address on all systems (e.g. via DHCP).
Normally the DNS requests will go to the configured address and are routed to the Pi, but as soon as the Pi does not respond to ping anymore that route will get disabled, the next one takes over, and it will process the traffic.
You can also have multiple servers. E.g. when you have a larger network, where you use BGP or OSPF to route the traffic, you can have multiple places in the network where traffic for that anycast address is routed to a local server. As soon as the server fails, the route disappears, BGP/OSPF will no longer distribute it, and another route to another place in the network where you have this address configured will take over.
Very powerful concept for such failovers... and of course the big players use this all the time, e.g. to provide the service for 1.1.1.1 or 8.8.8.8.
eb123456
Mon Aug 16, 2021 5:12 am
ok thank you this is definitely very informative. I was wondering how 1.1.1.1 and 8.8.8.8 could work with the `static` IP.
Any chance you can give me a bit more detail to set it up though? I am a beginner with both mikrotik and pihole.
Thanks!
shafiqrahman
Mon Aug 16, 2021 12:49 pm
what do you mean
most probably not
To me, the only thing I needed is to determine whether pihole is up or down. That , what the script does. It only checks whether pihole can resolve or not, then change accordingly. For instances , when the internet is down it also change the route through the router.
Users browsing this forum: djfearless and 6 guests
