p3rad0x
Long time Member
Long time Member
Export specific address list
Fri Jun 26, 2020 12:13 pm
Good day all,
I need to export a specific address list that contains over a 1000 entries. then fetch the file using FTP and upload it to a different router.
Fetching a file via FTP works 100% but exporting the specific address list is being a pain.
I followed this post
viewtopic.php?t=56167&sid=18eb6d53d5f0b ... 4a7bfb4f25
Since it's 5 years old I wonder if some of the syntax didn't change that is causing it to fail
Any ideas?
There you go then you touched something ;-) : it only takes a change in wind direction to screw with your nat :-)
Jotne
Re: Export specific address list
Fri Jun 26, 2020 8:29 pm
I can send the address list to Splunk using script. On Splunk you can do a lot of stuff with it. What is your goal?
How to use Splunk to monitor your MikroTik Router(s)
MikroTik->Splunk
p3rad0x
Long time Member
Long time Member
Mon Jun 29, 2020 12:26 pm
I want to use it for non-payer IP's on a second router
Users browsing this forum: No registered users and 19 guests
