dwkwong
IP cloud public address into variable
Tue Jun 30, 2020 4:39 am
Hi, I am new to scripting in Mikrotik, how to get a non-list type value into a variable, e.g. below, how to get below address into " :global public_ipv4"
[admin@MikroTik] /ip cloud print
ddns-enabled: yes
ddns-update-interval: none
update-time: yes
public-address: 159.148.147.196
public-address-ipv6: 2a02:610:7501:1000::2
dns-name: 529c0491d41c.sn.mynetname.net
status: updated
vecernik87
Long time Member
Long time Member
Re: IP cloud public address into variable
Tue Jun 30, 2020 4:55 am
print the data into console:
:put [/ip cloud get public-address]
Save into variable:
:global public_ipv4 [/ip cloud get public-address]
Enjoy :)
nichky
Long time Member
Long time Member
Tue Jun 30, 2020 5:44 am
@vecernik87
What does it do?
/ip cloud advanced set use-local-address=yes
can you give us an example, and on which causes can we use?
Nikola Suminoski
MikroTik Consultan
MTCRE l MTCWE
!) Safe Mode is your friend;
jvanhambelgium
Tue Jun 30, 2020 7:55 am
RTFM I guess,
use-local-address (yes | no; Default: no)
By default, the DNS name will be assigned to the detected public address (from the UDP packet header). If you wish to send your "local" or "internal" IP address, then set this to yes
So no, you don't want to enable this feature if you intent to use the "published URL" to access public services.
Give it a try and see what IP ends up as registered.
Users browsing this forum: Geyonk and 26 guests
