MUM Europe 2020
Equis
Forum Veteran
Forum Veteran
Firewall Mark based on Load
Sun Jun 17, 2007 10:00 am
Hello
If my link is at 90% I'd like to turn on a rule that opens another link.
any idea's how to monitor this and enable the rule?
Perhaps setup a rule and count the trafic over a 5 min period and if its over X amount open the link, if its less close the link?
cmit
Re: Firewall Mark based on Load
Mon Jun 18, 2007 9:44 am
Easier ;)
Look at the "/tool traffic-monitor" feature - it's built exactly for that: To run a script when bandwidth on a link goes above/below a certain bandwidth.
Does that help?
Best regards,
Christian Meis
Equis
Forum Veteran
Forum Veteran
Mon Jun 18, 2007 10:01 am
"jaw drops"
Thanks sooo much!
cmit
Mon Jun 18, 2007 10:08 am
Best regards,
Christian Meis
Equis
Forum Veteran
Forum Veteran
Mon Jun 18, 2007 10:10 am
Hello
With traffic monitor how often does it run, every second?
Thanks for any help!
cmit
Mon Jun 18, 2007 10:19 am
Sorry, don't know that...
Also, in the manual it has an example that says 15kbps but the example says 15000, is thata typo?
I'd say that's the usual "easy-to-interpret" way many people use, although 15 kbps actually would be 15360, not 15000.
Best regards,
Christian Meis
Equis
Forum Veteran
Forum Veteran
Mon Jun 18, 2007 10:33 am
You are too quick, I removed that question because I am a ding and figured it out :-)
Users browsing this forum: oskarsk and 17 guests
