jjtag2301
disable a rule when a provider crashes?
Tue Nov 03, 2020 6:07 pm
Good morning everyone, I'm in a problem ... I have a ccr1072 with many rules and everything is in static routing mode .. so when a provider leaves, I have to change those clients in both mangle and nat .. is there any way so that when the provider leaves ... these rules change automatically with a script so that you don't have to move every time you leave ...
Thanks a lot
deshabillitar una regla cuando se caiga un proveedor?
buenos dias a todos, estoy en un problema... tengo un ccr1072 con bastantes reglas y todo esta en modo ruteo estatico.. entonces cuando se va un proveedor, tengo que cambiar a esos clientes tanto en mangle como en nat .. hay alguna manera para que cuando se vaya el proveedor.. estas reglas cambien de manera automatica con algun script para no tener que estar moviendo cada vez que se vaya...
Muchas gracias
erkexzcx
Re: disable a rule when a provider crashes?
Tue Nov 03, 2020 10:26 pm
I am not sure what you are asking, but I would say "yes, it's possible".
gotsprings
Thu Nov 26, 2020 9:37 pm
You could check if an interface is active. Then if than based on that.
"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
Users browsing this forum: No registered users and 23 guests
