OliverST
Find and list filter by comment
Mon Nov 09, 2020 8:22 pm
Hi, i write some app and the server-side code is php.
need to select and list the filter by comment. This part will be for enabling - disabling filters like blocking youtube or some games
could someone help me please.
thx
$ARRAY = $API->comm('/ip/firewall/filter/print', false);
msatter
Re: Find and list filter by comment
Mon Nov 09, 2020 8:46 pm
/ip firewall filter disable [:find comment~"Yoeptube"]; This is in ROS script.
Replace Yoeptube with you use and it can also a partly match like tube because of the ~ instead of a =
Loving my freedom and so, no Twitter, no Facebook/Instagram/WhatsApp, no Apple and no Google/Alphabet.
Running:
RouterOS 6.48 / Winbox 3.27 64bits
OliverST
Mon Nov 09, 2020 9:05 pm
Thank you , will try it
now i have like this:
$API->comm("/ip/firewall/filter/getall", array("?comment" => "BLOCKED"));
msatter
Mon Nov 09, 2020 9:28 pm
Let RouterOS do this for you and look at how you normally enable and disable lines.
You are now collecting the lines and that is not needed.
Running:
Users browsing this forum: No registered users and 19 guests
