seidi
Run command in specific timeframe
Sun Nov 15, 2020 12:02 am
I am relativ new to Mikrotik. I want to run a script every minute but only between only between 03:00am and 04:00am.
When I see it correct the scheduler can run commands only in an intervall but not in a timeframe.
Does someone has an idea how a script should look like which I can execute with the scheduler every 2 minutes. I assume there is a way to make this script first check the time and then execute the command when it is between 3 and 4
inteq
Re: Run command in specific timeframe
Sun Nov 15, 2020 7:25 pm
See if this helps:
:local time [/system clock get time];
:if ($time >= "03:00:00" || $time <= "04:00:00") do={ :log warning hammer time }
seidi
Sun Nov 15, 2020 7:37 pm
do you think that I have to post here my own schript?
do={ :log warning hammer time } --> for exampe do={ script }
inteq
Sun Nov 15, 2020 7:39 pm
Execute your command inside the do={ }
seidi
Sun Nov 15, 2020 8:17 pm
I tried the following
put the following into a script
:if ($time >= "18:00:00" || $time <= "18:45:00") do={ ip ipsec active-peers kill-connections }
But it looks luike that the time frame is regocnizes and the command runs every time
inteq
Sun Nov 15, 2020 11:31 pm
Just double checked and it seems RouterOS does not support this type of time calculation without extra math involved.
Users browsing this forum: No registered users and 44 guests
