IYARINDRA
Removing Certificate
Wed Nov 18, 2020 6:44 pm
I tried to removed the certificates ... It's run fine on terminal but not in script.
For example:
/certificate
remove 0
remove 1
remove 2
remove 3
remove 4
remove 5
remove 6
remove 7
remove 8
remove 9
remove 10
In terminal, everything is perfect. But when I run it from script, it's not working.
Or is there any workaround?
eworm
Forum Veteran
Forum Veteran
Re: Removing Certificate
Sun Nov 22, 2020 6:04 pm
You should never ever use index numbers in scripts. These are just temporary and refer to the last print.
To remove all certificates use this:
/certificate remove [ find ];
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
Jotne
Re: Removing Certificate  [SOLVED]
Mon Nov 23, 2020 9:11 pm
Just a comment to:
This will remove all certificate, if that is your intention
If you just want to remove some:
/certificate remove  [find where name~"cert_name"]
Why do not use Splunk to monitor your MikroTik Router(s)? Look at this page in how to set it up.
MikroTik->Splunk
msatter
Mon Nov 23, 2020 9:43 pm
You can use print in a script by adding without-paging and as stated using numbers is not the best way to do this.
Loving my freedom and so, no Twitter, no Facebook/Instagram/WhatsApp, no Apple and no Google/Alphabet.
Running:
RouterOS 6.48 / Winbox 3.27 64bits
IYARINDRA
Tue Nov 24, 2020 3:53 am
Thank you very much everyone.
Users browsing this forum: No registered users and 37 guests
