ilium007
Updating CA root certs regularly
Fri Nov 27, 2020 1:58 pm
What is the best way to update CA root certs? I am running the script below every 7 days but I wondered if there is a better way to work out if they actually *need* updating before downloading, deleting and replacing certs every week.
Also - can running this every week damage flash RAM (or whatever memory is inside it).
  :do {
      /tool fetch url=https://mkcert.org/generate/ check-certificate=yes dst-path=cacert.pem;
      /certificate remove [find];
      /certificate import file-name=cacert.pem passphrase="";
      /file remove cacert.pem;
      :log info ("Updated certificate trust store");
  } on-error={
      :log error ("Failed to update certificate trust store");
pe1chl
Re: Updating CA root certs regularly
Fri Nov 27, 2020 2:23 pm
Completely unnecessary to update them that often! Once every 3 months should be more than enough, maybe even once per year.
ilium007
Fri Nov 27, 2020 2:27 pm
ok, thanks
eworm
Forum Veteran
Forum Veteran
Fri Nov 27, 2020 7:10 pm
No need to remove all certificates... You could just remove the expired ones to clean up.
/certificate remove [ find where authority expired ];
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
ilium007
Sat Nov 28, 2020 3:31 pm
Thanks - will the certificate import command then only import the new ones or will it write them all again?
ilium007
Sat Nov 28, 2020 3:32 pm
So if I run 3 monthly and a cert expires the day after the last script run then potentially I wait 3 months for this remote site to update root certs so the dynamic DNS IP update script can run via https.
pe1chl
Sat Nov 28, 2020 3:47 pm
It would be very bad practice for a certificate issuer to update their root certs only the day before they expire!
Remember all certs issued to clients depend on the root cert to be valid at least as long as the issued certificate.
As these are valid often for a year, the new root cert should be issued at least a year before the old one expires.
And these are usually valid for 10 years or so.
ilium007
Sat Nov 28, 2020 3:49 pm
That makes perfect sense! Thanks.
ilium007
Sat Nov 28, 2020 3:52 pm
I will run this every 6months then. Is there any way to only import the certs that expired or will this import all and overwrite existing certs?
  :do {
  } on-error={
eworm
Forum Veteran
Forum Veteran
Re: Updating CA root certs regularly  [SOLVED]
Sun Nov 29, 2020 1:10 am
Certificates that do not change are untouched. Have a look at the import output, it should give some numbers.
Users browsing this forum: No registered users and 30 guests
