josecat
Use of Variables on firewall src-address
Sun Nov 29, 2020 12:25 am
I´m traying to do this:
:global lan "192.168.250.0/24"
add action=drop chain=forward comment="Drop packets from LAN Not in LAN IP Range" in-interface-list=LOCAL_LAN log=yes log-prefix=!LAN_TOWAN_ src-address=!$lan
It seems that variables can´t be used on src-address with negation wildcard !......
If i make the following works fine:
add action=drop chain=forward comment="Drop packets from LAN Not in LAN IP Range" in-interface-list=LOCAL_LAN log=yes log-prefix=!LAN_TOWAN_ src-address=$lan
Where i´m making a mistake?
Thanks in advance.
Sob
Re: Use of Variables on firewall src-address  [SOLVED]
Sun Nov 29, 2020 12:50 am
You can make the "!" part of string, either when you define it, or like this:
src-address=("!".$lan)
Excessive quoting is useless and annoying. If you use it, please consider if you could do without it.
josecat
Sun Nov 29, 2020 1:13 am
Thanks very much Sob for your fast and correct response. It works
Users browsing this forum: No registered users and 27 guests
