luca1234567
Super-Easy script to create dir
Sun Nov 29, 2020 2:52 am
I found 4 super-easy, it may also customized, scritp to create a full path of a folder.
- NO need of FTP service enable
- NO need of Firewall config
- NO need of User\Password config
- NO need external scritp
- May be easy included in other script
:local CreateDirNewPath "NewDir/NewSubDir"
:do {
  /tool fetch address=127.0.0.1 port=443 mode=https src-path="NotExist" dst-path=($CreateDirNewPath."/NotExist")
  /file remove ($CreateDirNewPath."/NotExist")
 } on-error={ }
:do {
  /tool fetch https://127.0.0.1/NotExist dst-path=($CreateDirNewPath."/NotExist")
 } on-error={ }
This is if you not want "status:failed" in terminal.
:execute {
  :do {
    /tool fetch address=127.0.0.1 port=21 mode=ftp src-path="NotExist" dst-path=($CreateDirNewPath."/NotExist")
   } on-error={ }
This if you can use global variable
:global CreateDirNewPath "NewDir/NewSubDir"
:execute {
  :do {
   } on-error={ }
I suggest to Mikrotik to correct also the scritp to https://wiki.mikrotik.com/wiki/Script_t ... _directory
Best regards
Best regards.
satman1w
Re: Super-Easy script to create dir
Mon Nov 30, 2020 1:34 pm
...or you can create folder on your desktop and just drop it in your Winbox / Files wherever you want..
mozerd
Mon Nov 30, 2020 2:01 pm
Following is SUPER easy way of creating a dir using Terminal
/ip smb shares add name=sharethis directory=moab
/ip smb shares remove [find name=sharethis]
The 1st directive will create the directory while the 2nd directive will remove the share that is not needed.
bpwl
Mon Nov 30, 2020 2:14 pm
Make and delete a backup, in the wanted directory.?
luca1234567
Mon Nov 30, 2020 3:31 pm
@satman1w: This is a method to create it automaticaluy via scritp, or you want that the router call you when it need to create a directory ?
@mozerd: I test the method /ip smb shares on RouterOS v4. and it CANNOT create new sub-folder like NewDir/NewDir2/NewDir3/ in one command. Can you try.
@bpwl: Why write not wanted data, to next delete ?
WHY mikrotik not implement a full set of command to manage file ?
Like copy file, move file, copydirectory, move directory, create directory, etc.
WHY ???
Best regards.
mozerd
Mon Nov 30, 2020 3:52 pm
@luca1234567
You are 100% correct .... I am not able to create new sub-folders like described ..... no problem with root folders.
CZFan
Location: South Africa, Krugersdorp (Home town of Brad Binder)
Mon Nov 30, 2020 11:38 pm
Use winscp to create folder/sub folder?
MTCNA, MTCTCE, MTCRE & MTCINE
luca1234567
Mon Nov 30, 2020 11:43 pm
@CZFan
I repeat:
Best regards.
satman1w
Tue Dec 01, 2020 2:37 pm
I repeat:
[/quote]
You're right, but I never had a need to create folders dynamically on Mikrotik router... When that will happen, I will definitely use one of your scripts.
regards
Users browsing this forum: Google [Bot] and 32 guests
