dakobg
duplicated rules
Fri Dec 04, 2020 9:32 pm
Is there a good way to avoid duplicated rules in ip firewall filter ? How to sort rules via scripting or cmd (rules always to be in the same order 1,2,3 etc. ) ?
For example via cmd if execute the same rule , this rule is added several times, it is possible to avoid that ?
note: this example is for duplicate rules ignore it as content :)
[admin@ros1] > ip firewall filter print
Flags: X - disabled, I - invalid; D - dynamic
[admin@ros1] > /ip firewall filter add dst-address=8.8.8.8 chain=forward comment=test_rule
0 ;;; test_rule
chain=forward dst-address=8.8.8.8
1 ;;; test_rule
2 ;;; test_rule
Another example
[admin@ros1] > /ip firewall filter add dst-address=8.8.8.8 chain=forward comment=test_rule_1
[admin@ros1] > /ip firewall filter add dst-address=8.8.4.4 chain=forward comment=test_rule_2
0 ;;; test_rule_1
1 ;;; test_rule_2
chain=forward dst-address=8.8.4.4
0 ;;; test_rule_1
1 ;;; test_rule_2
2 ;;; test_rule_1
3 ;;; test_rule_2
[admin@ros1] >
Sob
Re: duplicated rules
Fri Dec 04, 2020 9:43 pm
You most likely don't want any automatic sorting, because order of rules matters. You could sort a subset of them without breaking anything, but you would first have to define what can be touched and what can't, which may be difficult. A separate chain for "sortable" rules could work, but if you'd add that, you might as well be careful and just watch what you're adding.
Excessive quoting is useless and annoying. If you use it, please consider if you could do without it.
dakobg
Fri Dec 04, 2020 9:51 pm
Yes I agree, but my main problem is if I want always to have the same rules during update with script or other automation
For example
1st script run will add rules A,B,C,D
2nd run to not add A,B,C,D if they already exist and only add new rules
Ideally must be for example on 2nd run A,B, new rule, C,D, new rule, new rule, etc.
Sob
Fri Dec 04, 2020 10:03 pm
In theory, a script could check if some rule exists before adding it. It would definitely make it more complex. But I'm not sure if it's even possible, because it would mean searching for rules that have certain parameters and also don't have any other parameters. A workaround would be to use rules uniquely identified by comments, and use those to find them. But you would have to make sure that nobody would change any of those rules manually.
But maybe somebody else will have better idea, RouterOS scripting and myself are not exactly friends.
dakobg
Fri Dec 04, 2020 10:32 pm
So I hope there is a good way to do that without complexity for this reason I'm asking and for order number
If we have rules
0 A
1 B
2 D
3 C
I think theoretically must be something like this
If new rule with number 2 is not D then replace it, if is the same do nothing
Or at lease do not add new rule D with number 5
Anyway if some one have easy solution .. if there is no such solution let me know as well
dakobg
Fri Dec 04, 2020 10:44 pm
Actually look like ip firewall filter set numbers= whatever do the job ! Almost
Users browsing this forum: No registered users and 39 guests
