mk13139
Pi-hole forced DNS redirection with failover script
Tue Dec 08, 2020 1:50 pm
I'm trying to create a Pi-hole DNS failover script, without luck so far.
Currently I have a Pi-hole in my network with IP address 192.168.18.2. The router has an outgoing public DNS of 1.1.1.1 and 1.0.0.1. The DHCP server has DNS 192.168.18.1 (router gateway) for the clients.
I've added the following NAT rules to force all DNS through the Pi-hole:
add chain=dstnat action=dst-nat to-addresses=192.168.18.2 protocol=udp src-address=!192.168.18.2 dst-address=!192.168.18.2 dst-port=53 comment="piholeNAT1"
add chain=dstnat action=dst-nat to-addresses=192.168.18.2 protocol=tcp src-address=!192.168.18.2 dst-address=!192.168.18.2 dst-port=53 comment="piholeNAT2"
add chain=srcnat action=masquerade protocol=udp src-address=192.168.18.0/24 dst-address=192.168.18.2 dst-port=53 comment="piholeNAT3"
add chain=srcnat action=masquerade protocol=tcp src-address=192.168.18.0/24 dst-address=192.168.18.2 dst-port=53 comment="piholeNAT4"
What I would like to do in case of failure of the Pi-hole is disabling these NAT rules. When these NAT rules are disabled, the clients DNS will go through the router gateway and public DNS 1.1.1.1/1.0.0.1 like normal until the Pi-hole is up again (NAT rules get enabled again and DNS redirect to Pi-hole).
I've created the following script, scheduled at an interval of 30 seconds:
:local piholeDNS "192.168.18.2"
:local testDomain "www.google.com"
:if ([/ip firewall nat [find comment="piholeNAT1"] enabled]) do={
    :do {
        :resolve $testDomain server $piholeDNS
    } on-error={
		/ip firewall nat disable [find comment="piholeNAT1"]
		/ip firewall nat disable [find comment="piholeNAT2"]
		/ip firewall nat disable [find comment="piholeNAT3"]
		/ip firewall nat disable [find comment="piholeNAT4"]
} else={
    :do {
		/ip firewall nat enable [find comment="piholeNAT1"]
		/ip firewall nat enable [find comment="piholeNAT2"]
		/ip firewall nat enable [find comment="piholeNAT3"]
		/ip firewall nat enable [find comment="piholeNAT4"]
    } on-error={}
When I disconnect the Pi-hole as a failure test, the NAT rules don't get disabled. So something is obviously wrong in the script. Can somebody help me out?
mk13139
Re: Pi-hole DNS failover script  [SOLVED]
Tue Dec 08, 2020 4:39 pm
Nevermind! I looked again carefully and figured that the fault was in getting the state value of the nat rule.
The working code for forced redirection through Pi-hole with DNS failover is as follows:
:local piholedown [/ip firewall nat get value-name=disabled [find comment="piholeNAT1"]]
:if ($piholedown = false) do={
    :do {
    } on-error={
		/ip firewall nat;
			disable [find comment="piholeNAT1"];
			disable [find comment="piholeNAT2"];
			disable [find comment="piholeNAT3"];
			disable [find comment="piholeNAT4"];
} else={
    :do {
        :resolve $testDomain server $piholeDNS;
		/ip firewall nat;
			enable [find comment="piholeNAT1"];
			enable [find comment="piholeNAT2"];
			enable [find comment="piholeNAT3"];
			enable [find comment="piholeNAT4"];
    } on-error={}
With the following NAT rules (*edit: added in-interface LAN bridge to dst-nat rules to prevent exposure of port 53 to outside world):
add chain=dstnat action=dst-nat to-addresses=192.168.18.2 in-interface=bridge protocol=udp src-address=!192.168.18.2 dst-address=!192.168.18.2 dst-port=53 comment="piholeNAT1"
add chain=dstnat action=dst-nat to-addresses=192.168.18.2 in-interface=bridge protocol=tcp src-address=!192.168.18.2 dst-address=!192.168.18.2 dst-port=53 comment="piholeNAT2"
zilexa
Fri Feb 12, 2021 11:20 am
With these rules, is the device running pihole (192.168.18.2) able to use the internet, resolve domains?
In my case pihole runs on my homeserver which does need the ability to have normal internet access/resolve domains. It seems, to prevent a loop, you actually exclude the pihole, but then how can that device resolve domains?
mk13139
Fri Feb 12, 2021 12:03 pm
Hi Zilexa,
Yes, with these rules the PiHole is the only device in the network which is able to resolve domains using an external DNS server (the PiHole is explicitly excluded in above rules).
These rules force a redirect for all DNS queries from all other devices in the network to the PiHole.
zilexa
Fri Feb 12, 2021 12:27 pm
Hi Zilexa,
Thanks, I tried and luckily I am still able to resolve dns queries coming from my server itself :)
The biggest downside though: You no longer have per-client stats in PiHole. PiHole will see only 1 client: your router.
But I guess that is acceptable for now.
Users browsing this forum: No registered users and 12 guests
