sin3vil
Getting LTE bus interface via script
Sun Dec 13, 2020 7:23 pm
Hello everyone,
Using an RB953 with two LTE modules.
For reasons I'd prefer not to go into detail, I need to run /system routerboard usb power-reset duration=3s bus=1 command for a specific interface, say lte1.
The command requires the bus interface to reset power to.
Is there a way to get the bus a specific LTE interface is on, in a scriptable manner?
Interface name, lte1, lte2 etc does not seem to always coincide with which bus/slot it's plugged in.
You could possible get it via /system resource usb print, but this does not work if both modules are the same.
[admin@LTE1-2] > sys resource  usb print detail
 0 device="1-0" vendor="Linux 3.3.5 ehci_hcd" name="RB400 EHCI" serial-number="rb400_usb" vendor-id="0x1d6b" device-id="0x0002" speed="480" ports=1 usb-version=" 2.00"
 1 device="2-0" vendor="Linux 3.3.5 ehci_hcd" name="RB400 EHCI" serial-number="rb400_usb" vendor-id="0x1d6b" device-id="0x0002" speed="480" ports=1 usb-version=" 2.00"
 2 device="2-1" vendor="MikroTik" name="R11e-LTE6" serial-number="000000000000" vendor-id="0x2cd2" device-id="0x0004" speed="480" usb-version=" 2.00"
 3 device="1-1" vendor="MikroTik" name="R11e-LTE6" serial-number="000000000000" vendor-id="0x2cd2" device-id="0x0004" speed="480" usb-version=" 2.00"
Running the command blind, for both bus interfaces, is not an option.
SiB
Re: Getting LTE bus interface via script
Mon Dec 14, 2020 12:25 pm
In /Interface lte we not have detail from what bus specific lte is connected.
You must do test way. Of course we should see SN here and can recognise unit by SN itself but this now work :(
/system routerboard usb power-reset duration=1s bus=1 ; #do reboot a lte1 or lte2 means device 1-1
/system routerboard usb power-reset duration=1s bus=2 ; # should reboot second lte module, means 2-1
This is constance and not swap.
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
At vacation until 15.jan.2021
Users browsing this forum: rhapael14 and 32 guests
