eldoncito2019
How do I disable a rule in IP ROUTE?
Sat Dec 19, 2020 3:20 pm
Hello, how do I disable a rule in IP ROUTE with a script?
Tank you.
ELDONCITO.
eldoncito2019
Re: How do I disable a rule in IP ROUTE?
Sun Dec 20, 2020 11:44 am
Can someone give me a hand?
Sob
Re: How do I disable a rule in IP ROUTE?  [SOLVED]
Mon Dec 21, 2020 1:16 am
Examples:
/ip route disable [find comment="test"]
/ip route disable [find dst-address=10.0.0.0/8]
/ip route disable [find dst-address=0.0.0.0/0 gateway=10.1.1.1]
Excessive quoting is useless and annoying. If you use it, please consider if you could do without it.
eldoncito2019
Mon Dec 21, 2020 5:11 am
Examples:
Thanks friend SOB then I have the following script: if ([/ ping 8.8.8.8 interface = "ETHERT 2" count = 6] = 0) do = {/ ip route disable [find comment = "test"]
How would I enable the rule in IP Route, when the ping to DNS 8.8.8.8 responds?
Tank you
msatter
Mon Dec 21, 2020 12:00 pm
You can't. If you don't have an active connection to the internet you can't ping anything on the internet.
Please stop with creating postings about this and have a read of what others suggested in answer to your many postings on this.
Loving my freedom and so, no Twitter, no Facebook/Instagram/WhatsApp, no Apple and no Google/Alphabet.
Running:
RouterOS 6.48 / Winbox 3.27 64bits
Users browsing this forum: Google [Bot] and 51 guests
