I have taken over managing a setup for my inlaws. It was installed by a local installer. The main router is 960pgs powering a pair of access points. The firmware on it appears to be a customized version of routerOS from https://www.custom-integration-solutions.com/
Winbox and ssh have been disabled on the router, but the api is available via the port.
Webfig is enabled, but only shows a subset of the information.
I am wanting to enable the winbox port or ssh so I can get a good view of the configuration. Is the API able to enable ssh or winbox services?
Thanks.
