rb77
Script Error
Mon Jan 25, 2021 10:26 am
Hello@all,
maybe someone can help me.
Router: MikroTik hex
OS: v6.48
I´ve created a script 'Test' unter /system Scripts as shown below.
On execution i get the following error message:
[admin@ROUTER] > system script run Test
expected command name (line 4 column 24)
:local piholeDNS "10.0.0.1"
:local testDomain "www.google.com"
:if ([/ip firewall nat [find comment="DNS - Redirect all DNS requests to pihole"] enabled]) do={
    :do {
        :resolve $testDomain server $piholeDNS
    } on-error={
		/ip firewall nat disable [find comment="DNS - Redirect all DNS requests to pihole"]
		/ip firewall nat disable [find comment="DNS - Traffic from pihole to www"]
} else={
    :do {
		/ip firewall nat enable [find comment="DNS - Redirect all DNS requests to pihole"]
		/ip firewall nat enable [find comment="DNS - Traffic from pihole to www"]
    } on-error={}
I cannot fint the problem, maybe i´m missing something and someone can help me.
Thank you.
eworm
Forum Veteran
Forum Veteran
Re: Script Error
Tue Jan 26, 2021 5:27 pm
Yes, you are missing a command. 😜
The fourth line should look something like this:
:if ([/ip firewall nat get [find comment="DNS - Redirect all DNS requests to pihole"] disabled] = false) do={
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
Jotne
Re: Script Error
Tue Jan 26, 2021 6:58 pm
Since all are done in the same command folder you can go to the command folder and shorten all commands. Eks:
:if ([get [find comment="DNS - Redirect all DNS requests to pihole"] disabled] = false) do={
    :do {
    } on-error={
} else={
    :do {
    } on-error={}
Why do not use Splunk to monitor your MikroTik Router(s)? Look at this page in how to set it up.
MikroTik->Splunk
rb77
Re: Script Error
Fri Jan 29, 2021 9:06 pm
Hey Thank you.
It works :-)
Users browsing this forum: No registered users and 21 guests
