angboontiong
PPPOE with auto mangle and queue tree
Mon Jan 25, 2021 8:57 pm
i had search over the web but i cannot see this thing so i raise a question here.
i had 5 type of customer, whereby they had 10Mbps, 30Mbps, 50Mbps, 70Mbps and 100Mbps.
and each of the package will be /29 for share group.
how can i add the script into the pppoe server, when user authenticated, it will mangle it and group it to the /29 for bandwidth sharing?
Jotne
Re: PPPOE with auto mangle and queue tree
Tue Jan 26, 2021 8:38 am
Why not set limit to profile and add user to various profile groups with different speed limit?
Why do not use Splunk to monitor your MikroTik Router(s)? Look at this page in how to set it up.
MikroTik->Splunk
angboontiong
Tue Jan 26, 2021 3:49 pm
I'm using radius and the way u do just will assign to simple queues.
jprietove
Trainer
Trainer
Tue Jan 26, 2021 5:43 pm
Using Radius Attribute "Mikrotik-Rate-Limit" you can assign a queue dynamically. https://wiki.mikrotik.com/wiki/Manual:R ... Attributes
angboontiong
Tue Jan 26, 2021 8:09 pm
That method will assigne the pppoe client with simple queue.
What I mean is it will.move the same package customer to /29 simple queue ... Something like that. /29 = 7 ip in same group.
Users browsing this forum: No registered users and 37 guests
