SpiderMattX
Useful package / RouterBoard update scripts that work with Unimus
Fri Jan 29, 2021 1:53 pm
Just figured I would share these since they just passed their final test for production last night. I have made some basic scripts that can be easily used stand-alone with the scheduler or can be deployed via Unimus for centralized management. The scripts simply handle the two-step process of changing the software / firmware version of a RouterOS device. I realize that the package manager has some basic functionality for this already but what it does not seem to do with ease, is allow one to downgrade without using different commands.
With this script, you simply define the target version you want to change to (whether it's older or newer than the current version installed) and it will handle the rest.
Here is the raw script that can be manually loaded onto a RouterOS device:
:global TargetVer "6.47.4"
:global Architecture
:global PkgVer
:global PkgVer1
:global PkgVer2
:global PkgVer3
:global RbVer
:global RbVer1
:global RbVer2
:global RbVer3
:global TargetVer1
:global TargetVer2
:global TargetVer3
:global PackageURL
:set Architecture [/system resource get architecture-name]
:set PkgVer "$[/system package get system version]"
:set PkgVer1 [:pick $PkgVer 0 1]
:set PkgVer2 [:pick $PkgVer 2 4]
:set PkgVer3 [:pick $PkgVer 5 6]
:set RbVer "$[/system routerboard get current-firmware]"
:set RbVer1 [:pick $RbVer 0 1]
:set RbVer2 [:pick $RbVer 2 4]
:set RbVer3 [:pick $RbVer 5 6]
:set PkgVer1 [:tonum $PkgVer1]
:set PkgVer2 [:tonum $PkgVer2]
:set PkgVer3 [:tonum $PkgVer3]
:set RbVer1 [:tonum $RbVer1]
:set RbVer2 [:tonum $RbVer2]
:set RbVer3 [:tonum $RbVer3]
:set TargetVer1 [:pick $TargetVer 0 1]
:set TargetVer2 [:pick $TargetVer 2 4]
:set TargetVer3 [:pick $TargetVer 5 6]
:set TargetVer1 [:tonum $TargetVer1]
:set TargetVer2 [:tonum $TargetVer2]
:set TargetVer3 [:tonum $TargetVer3]
:set PackageURL "https://download.mikrotik.com/routeros/$TargetVer/routeros-$Architecture-$TargetVer.npk"
if ($PkgVer != $TargetVer) do={
	:log info "Package version does not match target version. Downloading package file from $PackageURL.";
	/tool fetch url=$PackageURL;
	if ($PkgVer1 > $TargetVer1 || $PkgVer2 > $TargetVer2 || $PkgVer3 > $TargetVer3) do={ :log info "Target package version is older than current package version. Executing downgrade..."; /system package downgrade; } else={ :log info "Target package version is newer than current package version. Executing upgrade..."; /system reboot; }
} else={
	if ($RbVer != $PkgVer) do={ :log info "RouterBoard firmware ($RbVer) does not match target version ($TargetVer). Executing upgrade..."; /system routerboard upgrade; /system reboot; } else={ :log info "Software and firmware currently match target version ($TargetVer). No changes being made."; }
Here is the script packaged for deployment via shell connection:
/system script remove update-software
/system script add name="update-software" policy="read,write,reboot,test,ftp,sensitive,policy" comment="Updates system software to declared target version." source=":global TargetVer \"6.47.4\"\r\n:global Architecture\r\n:global PkgVer\r\n:global PkgVer1\r\n:global PkgVer2\r\n:global PkgVer3\r\n:global RbVer\r\n:global RbVer1\r\n:global RbVer2\r\n:global RbVer3\r\n:global TargetVer1\r\n:global TargetVer2\r\n:global TargetVer3\r\n:global PackageURL\r\n:set Architecture [/system resource get architecture-name]\r\n:set PkgVer \"\$[/system package get system version]\"\r\n:set PkgVer1 [:pick \$PkgVer 0 1]\r\n:set PkgVer2 [:pick \$PkgVer 2 4]\r\n:set PkgVer3 [:pick \$PkgVer 5 6]\r\n:set RbVer \"\$[/system routerboard get current-firmware]\"\r\n:set RbVer1 [:pick \$RbVer 0 1]\r\n:set RbVer2 [:pick \$RbVer 2 4]\r\n:set RbVer3 [:pick \$RbVer 5 6]\r\n:set PkgVer1 [:tonum \$PkgVer1]\r\n:set PkgVer2 [:tonum \$PkgVer2]\r\n:set PkgVer3 [:tonum \$PkgVer3]\r\n:set RbVer1 [:tonum \$RbVer1]\r\n:set RbVer2 [:tonum \$RbVer2]\r\n:set RbVer3 [:tonum \$RbVer3]\r\n:set TargetVer1 [:pick \$TargetVer 0 1]\r\n:set TargetVer2 [:pick \$TargetVer 2 4]\r\n:set TargetVer3 [:pick \$TargetVer 5 6]\r\n:set TargetVer1 [:tonum \$TargetVer1]\r\n:set TargetVer2 [:tonum \$TargetVer2]\r\n:set TargetVer3 [:tonum \$TargetVer3]\r\n:set PackageURL \"https://download.mikrotik.com/routeros/\$TargetVer/routeros-\$Architecture-\$TargetVer.npk\"\r\nif (\$PkgVer != \$TargetVer) do={\r\n	:log info \"Package version does not match target version. Downloading package file from \$PackageURL.\";\r\n	/tool fetch url=\$PackageURL;\r\n	if (\$PkgVer1 > \$TargetVer1 || \$PkgVer2 > \$TargetVer2 || \$PkgVer3 > \$TargetVer3) do={ :log info \"Target package version is older than current package version. Executing downgrade...\"; /system package downgrade; } else={ :log info \"Target package version is newer than current package version. Executing upgrade...\"; /system reboot; }\r\n} else={\r\n	if (\$RbVer != \$PkgVer) do={ :log info \"RouterBoard firmware (\$RbVer) does not match target version (\$TargetVer). Executing upgrade...\"; /system routerboard upgrade; /system reboot; } else={ :log info \"Software and firmware currently match target version (\$TargetVer). No changes being made.\"; }\r\n}"
Here are additional deployment scripts for setting up the scheduler to execute the script:
/system scheduler remove update-software
/system scheduler remove update-firmware
/system scheduler add name="update-software" comment="Executes update-software script at 3am." start-date="jan/29/2021" start-time="03:00:00" policy="read,write,reboot,test,ftp,sensitive,policy" on-event=update-software
/system scheduler add name="update-firmware" comment="Executes update-software script at 3:10am." start-date="jan/29/2021" start-time="03:10:00" policy="read,write,reboot,test,ftp,sensitive,policy" on-event=update-software
No warranty provided, know what you're doing before you do it!
Enjoy!
SpiderMatt
"Those who would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety."
Users browsing this forum: No registered users and 23 guests
