th3j0k3r
Traffic Monitor tool script
Fri Jan 29, 2021 2:04 pm
Hi all,
So I setup on my mikrotik RB750GR3 router the settings from the link below:
https://wiki.mikrotik.com/wiki/Manual:T ... ic_Monitor
but when I test to see if it will disable or enable, it doesn't work. Is there a specific thing you are supposed to do for it to work?
I plugged in my laptop to the port (say ether3) and to check if it would enable, I manually disabled it, plugged it in and nothing happened.
Any suggestions?
Users browsing this forum: No registered users and 35 guests
