bourneagainsh
"\$(HOSTNAME)_\$(FIRMWARE)_\$(DATE)-\$(TIME)"
Sun Feb 07, 2021 12:28 am
I would like to name automatically my export file in the following format:
hEX_S-RB760iGS_6.48.1_20210206-193801
where:
hEX_S-RB760iGS - Hostname
_6.48.1 - Current Firmware
_20210206 - Current Date YYYYMMDD
-193801 - Current time HHMMSS
I have tried the following, but no luck:
export file="\$(HOSTNAME)_\$(FIRMWARE)_\$(DATE)-\$(TIME)"
Does anyone know how to achieve this for "export file" command?
mrz
Re: "\$(HOSTNAME)_\$(FIRMWARE)_\$(DATE)-\$(TIME)"
Mon Feb 08, 2021 10:08 am
file="$HOSTNAME_$FIRMWARE_$DATE-$TIME"
keeping in mind that all of those variables are actually defined.
bourneagainsh
Mon Feb 08, 2021 1:06 pm
Great, where do I need them to be defined? ;)
I have set Hostname, system knows the current firmware and date/time on Mikrotik.
On my PC's running Debian, when I backup my Firefox browser settings I execute:
tar -cvf BackUp_Firefox_$(hostname)_$(date +%Y%m%d-%H%M%S).tar -P ~/.mozilla/firefox/
so I guess, same approach does not work on MikroTik ....
Executing the:
/export file="$HOSTNAME_$FIRMWARE_$DATE-$TIME"
would result in file:
13 __-.rsc script 23.9KiB feb/08/2021 11:00:55
mrz
Mon Feb 08, 2021 2:31 pm
nostromog
Mon Feb 08, 2021 3:17 pm
where:
You could do something like
[admin@Mikrotik] > {/system; :put "$[identity get name]_$[routerboard get current-firmware ]_$[clock get date]-$[clock get time]"; / }
Mikrotik_7.1beta4_feb/08/2021-14:06:13
Or use
/system resource get version
instead of the installed firmware. You might also prefer
/system routerboard get serial-number
I used a curly brackets block to allow to "chdir" to /system, and save some typing, and then at the end "chdir" back to "/". If you know bash, you'll see that routeros uses
$(varname)
where bash uses
${varname}
, and
$[command]
where bash uses
$(command)
teknologs
Mon Feb 08, 2021 6:36 pm
where:
:local version [/system package update get installed-version]
:local GDate [/system clock get date]
:local Gtime [/system clock get time]
:local GDay [ :pick $GDate 4 6 ]
:local GMonth [ :pick $GDate 0 3 ]
:local GYear [ :pick $GDate 7 11 ]
:local GResult "$GDay $GMonth $GYear"
:local ExportConf ([/system identity get name])
/export compact file="$ExportConf-Version_$version-Date_$GResult-Time_$Gtime"
Users browsing this forum: No registered users and 39 guests
