galaxyaord
Sum values obtained with foreach
Sat Feb 13, 2021 9:49 am
Greetings. I want to obtain the limit-at variable of all the queues that correspond to a parent and add all its values in the same variable, how can I do this? I run the following commands:
 :foreach b in=[/queue simple find parent=example-parent] d={
	:global test [/queue simple get $b limit-at]; :put $test
but instead of giving me the total value they are printed individually line by line, for example:
1M / 5M
1M / 2M
2M / 1M
How can I do so that when consulting the variable for example $ result it gives me the total sum? In this case: put $result = 3M/8M
Emil66
Re: Sum values obtained with foreach
Sat Feb 13, 2021 11:44 am
Sums are obtained by adding stuff up. Computers only do what they're told. Try telling the computer to add something.
Hex S
galaxyaord
Sat Feb 13, 2021 2:58 pm
I publish precisely because I cannot find how to combine all the results in a single variable
Jotne
Sat Feb 13, 2021 8:05 pm
Split the data inn to two variables (do not need to use global her so use local variable)
Then sum up
https://wiki.mikrotik.com/wiki/Manual:S ... _Operators
Why do not use Splunk to monitor your MikroTik Router(s)? Look at this page in how to set it up.
MikroTik->Splunk
Users browsing this forum: Google [Bot] and 50 guests
