instalator
/ip/kid-control/pause kid1 not work
Mon Feb 15, 2021 11:19 am
How to send command
using CLI?
I get
no such command ()
in response. It looks like a space is being ignored.
normis
Re: /ip/kid-control/pause kid1 not work
Mon Feb 15, 2021 2:53 pm
[admin@1009up] > ip/kid-control/pause
command is valid. Are you running RouterOS v7? is there a kid named "kid1"?
instalator
Mon Feb 15, 2021 5:08 pm
This command pauses all recordings, and I only need one.
"[admin@MikroTik] > ip kid-control pause kid1" works via terminal, but I cannot execute it via api.
6.48
mrz
Mon Feb 15, 2021 5:54 pm
API is not the same as CLI syntax. You need to get ID and then perform action with the ID,
See api documentation and examples:
https://wiki.mikrotik.com/wiki/Manual:API
https://wiki.mikrotik.com/wiki/API_command_notes
instalator
Mon Feb 15, 2021 6:26 pm
I apologize if I put it wrong. I have other commands working through api including "ip kid-control pause", but it is "ip kid-control pause kid1" that does not work.
I am using the package https://github.com/gtjoseph/mikronode-ng
normis
Wed Feb 17, 2021 11:22 am
Please read above suggestion again:
instalator
Wed Feb 17, 2021 12:35 pm
'/ip/kid-control/print'
[{".id":"*1","name":"kid1","sun":"","mon":"","tue":"","wed":"","thu":"","fri":"","sat":"","rate-limit":"","tur-sun":"","tur-mon":"","tur-tue":"","tur-wed":"","tur-thu":"","tur-fri":"","tur-sat":"","paused":"false","blocked":"true","disabled":"false"},{".id":"*2","name":"kid2","sun":"","mon":"","tue":"","wed":"","thu":"","fri":"","sat":"","rate-limit":"","tur-sun":"","tur-mon":"","tur-tue":"","tur-wed":"","tur-thu":"","tur-fri":"","tur-sat":"","paused":"false","blocked":"true","disabled":"false"},{".id":"*3","name":"kid3","sun":"","mon":"","tue":"","wed":"","thu":"","fri":"","sat":"","rate-limit":"","tur-sun":"","tur-mon":"","tur-tue":"","tur-wed":"","tur-thu":"","tur-fri":"","tur-sat":"","paused":"false","blocked":"true","disabled":"false"}]
Thanks, the id works.
'/ip/kid-control/pause\n=.id=*1'
Confused that it does not work by name.
Users browsing this forum: No registered users and 33 guests
