pcunite
Append Bridge vlan values
Fri Feb 19, 2021 6:12 am
I'm attempting to set some values under the /interface bridge vlan command, namely the untagged property. Normally, I set this like so:
set bridge=BR1 tagged=ether4 [find vlan-ids=10].
However, I need a way to append the value to what is already present. Here's what I've cobbled together so far, but it does not work correctly.
A full example is shown below.
Example:
# Script Setup
/interface bridge add name=BR1 protocol-mode=none vlan-filtering=no
add bridge=BR1 untagged=ether2 vlan-ids=10
# How to Append "ether4" to array?
set bridge=BR1 untagged=([get value-name=untagged]",ether4") [find vlan-ids=10]
tdw
Re: Append Bridge vlan values
Fri Feb 19, 2021 3:56 pm
set untagged=([get value-name=untagged [find vlan-ids=10]],"ether4") [find vlan-ids=10]
Is there a reason you explicitly set the untagged= parameter as this will be dynamically populated from the pvid= parameter under /interface bridge port for bridge members and /interface bridge for the bridge itself. This avoids the possibility of mismatches which will cause unexpected behaviour.
pcunite
Fri Feb 19, 2021 9:04 pm
Is there a reason why you explicitly set the untagged= parameter as this will be dynamically populated.
I am considering removing lines referencing the untagged member because of the reasons you note. I also needed to set the tagged member as well. I really appreciate the help. I'm looking into how to set Hybrid ports in an easy to show way.
Users browsing this forum: No registered users and 31 guests
