tomislav91
get src ip from destination in firewall
Tue Feb 23, 2021 11:10 am
:local LocalSubnet [:pick [/ip firewall nat find where dst-add
ress=192.168.0.0/16] src-address]];
idea is to use local subnet for further scripting and i have one rule in nat and i want to exclude from that, so src subnets are different but that dst subnet are the same allways, so i want to get that ip into variable.
this vatiable catch nothing. Somewhere is mistake...
this is rule
add chain=srcnat dst-address=192.168.0.0/16 src-address=10.10.189.0/24
Jotne
Re: get src ip from destination in firewall
Tue Feb 23, 2021 1:09 pm
Do you get any output from running this form command prompt
:put [/ip firewall nat find where dst-address=192.168.0.0/16]
Why do not use Splunk to monitor your MikroTik Router(s)? Look at this page in how to set it up.
MikroTik->Splunk
tomislav91
Tue Feb 23, 2021 4:21 pm
nope
Jotne
Tue Feb 23, 2021 5:39 pm
You are missing quotes. Try
:put [/ip firewall nat find where dst-address="192.168.0.0/16"]
So this should give what you looking for:
:put [/ip firewall nat get [find where dst-address="192.168.0.0/16"] src-address]
MikroTik->Splunk
Users browsing this forum: Jotne, Lajci and 19 guests
