Lilarcor
match long domain name
Thu Mar 18, 2021 5:15 am
I want to set up static dns in ros for matching any long (over 5 characters) subdomains
eg. I want to match any domain like xyzxyz.example.com or abcabcabc.example.com, but don't want to match xyz.example.com or abcab.example.com.
I was using ^.*\{6,\}\.example.com, but what I got in static record is unknown record, ip is 0.0.0.0
Jotne
Re: match long domain name
Thu Mar 18, 2021 7:55 am
Why do you like to do that? An what to do if it match?
This is exactly one of the reason I would like DoH welcome. Noen of the ISP on the route to main DNS owner can not see nor alter my DNS request.
Lilarcor
Thu Mar 18, 2021 10:14 am
The reason I want to use it is for my NAS (unraid), which releases a new function in new version and needs DNS rebind to match a record for xxxxxx(radom ID, over 40 bit long).unraid.net, so I want have the match in my DNS static.
elico
Tue Mar 23, 2021 9:58 pm
The next works:
^([a-z0-9]|[a-z0-9][a-z0-9]|[a-z0-9][a-z0-9][a-z0-9]|[a-z0-9][a-z0-9][a-z0-9][a-z0-9]|[a-z0-9][a-z0-9][a-z0-9][a-z0-9][a-z0-9]).example.com
However I would have expected it to work with a {1,2,3,4,5}
msatter
Wed Mar 24, 2021 1:32 pm
Try this this one:
^[a-z0-9]{6,}\\.example\\.com\$
:put ("xyz.example.com" ~ "^[a-z0-9]{6,}\\.example\\.com\$") = false
:put ("xyzxyz.example.com" ~ "^[a-z0-9]{6,}\\.example\\.com\$") = true
You need extra "\" when you are inside a string/text in RouterOS.
:put "$variable \$ 100.00 for hundred dollars"
local variable 99; :put "$variable \$ 100.00 for hundred dollars"
elico
Wed Mar 24, 2021 2:47 pm
Try this this one:
It works only for scripts not for a static DNS regex.
msatter
Thu Mar 25, 2021 12:21 am
Bummer, really limited.
Quick and dirty and matching any character number or sign
......\.example\.com$
Lilarcor
Thu Mar 25, 2021 7:20 am
The next works:
Yours will match any subdomains with 1-6 characters. What I want is to match longer than 6 characters, like abcdefghijk.example.com
Lilarcor
Thu Mar 25, 2021 7:28 am
(........)+.unraid.net
Above works, thank you
msatter
Re: match long domain name  [SOLVED]
Thu Mar 25, 2021 5:11 pm
You have use th "\" because yous wiil also match
abcdefrunraid.net
Then using the "()" with the plussign will only match only multiples of the group.
So not abdcefg.unraid.net but it will match abcdefabcdef.unraid.net
Correct is:
.*......\.unraid\.net$
Lilarcor
Fri Mar 26, 2021 3:49 am
abcdefrunraid.net
Correct is:
Thanks for your answer
Users browsing this forum: No registered users and 56 guests
