Bytechanger
Disable port after disconnect client
Tue Apr 13, 2021 9:08 pm
HI,
i have an outdoor Wifi AP. I want to disable a port, wenn someone pull the LAN cable out of it.
I wann to use rb260gs. Ive seen scripts where you can disable port and check Connection speed, but nothing to check up/down the connection or an event on disconnect.
Greets
Byte
Bytechanger
Re: Disable port after disconnect client
Wed Apr 14, 2021 11:48 am
found a solution, but generel question, can I script on an switch or only on routeros?
I want to buy a rb260gs?!
Greets
Byte
Users browsing this forum: Google [Bot] and 19 guests
