efolch
Send Global Variable in Hotspot redirection
Fri Apr 16, 2021 4:55 am
Hello! I'm new in the forum and in scripting too.
I've made this script for get WLAN1 macAddress (i need send that info to external portal hotspot).
1) This is the script i made.. when I run it, I see in terminal that variable have been succesfull set:
:global macWlanLab [/interface get [/interface find default-name=wlan1] mac-address ];
log info "$macWlanLab";
2) I also see that "enviroment" is well set here:
[admin@Gateway] /system script environment> print
# NAME VALUE
0 macWlanLab XX:XX:XX:YY:YY:YY
3) In other hand I've configure the login.html hotspot, with this redirection params setting:
<form id="redirect" name="redirect" action="" method="post">
<input type="hidden" name="hotspotname" value="Gateway"/>
<input type="hidden" name="servername" value="$(server-name)"/>
<input type="hidden" name="mac" value="$(mac)"/>
<input type="hidden" name="ip" value="$(ip)"/>
<input type="hidden" name="username" value="$(username)"/>
<input type="hidden" name="link-login" value="$(link-login)"/>
<input type="hidden" name="link-orig" value="$(link-orig)"/>
<input type="hidden" name="error" value="$(error)"/>
<input type="hidden" name="chap-id" value="$(chap-id)"/>
<input type="hidden" name="chap-challenge" value="$(chap-challenge)"/>
<input type="hidden" name="link-login-only" value="$(link-login-only)"/>
<input type="hidden" name="macLab" value="$(macWlanLab)"/>
<input type="hidden" name="identity" value="$(identity)"/>
</form>
4) But when the redirection happends.. The value is not sent:
(see Image "Capture.PNG" attached).
Any help or diferrent approuch to send this custom param in first redirecction I'll be really grateful..
Thanks!
Eric
Users browsing this forum: No registered users and 32 guests
