amcrs
! Variables in firewall filters
Fri Apr 23, 2021 6:51 am
I have
:global eruWAN ether1
/ip firewall filter add chain=forward out-interface=!($eruWAN) ....
which the CLI doesn't like. Nor
/ip firewall filter add chain=forward out-interface=!$eruWAN ....
/ip firewall filter add chain=forward out-interface=(!$eruWAN) returns "Script Error: cannot logically negate string" which makes sense, but
/ip firewall filter add chain=forward out-interface=!ether1 .... works.
How can I use the variable $eruWAN there?
Jotne
Re: ! Variables in firewall filters
Fri Apr 23, 2021 12:18 pm
In cli wrap the code i brackets. {code}
mrz
Fri Apr 23, 2021 12:31 pm
As error says you cannot logically negate string.
by specifying !"string" you are trying to perform logic operation on string and then apply it as a value.
To pass ! as part of the value you should pass it as a part of string "!$your_var"
[admin@MikroTik] /ip/firewall/filter> add out-interface="!$x" chain=xx
[admin@MikroTik] /ip/firewall/filter> print
Flags: X - disabled, I - invalid; D - dynamic
 0    chain=xx out-interface=!ether1
rextended
Fri Apr 23, 2021 2:47 pm
do not matter, if you use GLOBAL, instead of local.
rextended
Re: ! Variables in firewall filters  [SOLVED]
Fri Apr 23, 2021 2:48 pm
sorry.. missing
:global x "ether1"
[admin@MikroTik] /ip/firewall/filter> :global x "ether1"
Users browsing this forum: No registered users and 17 guests
