v1nce
[HELP] Hotspot shared bandwidth with bandwidth management in simple queue
Tue May 04, 2021 11:09 pm
NEED HELP! I've been working and searching for solutions about this.
This script will do automatic simple queue adding with child queue which is for bandwidth management using mangle rules.
But what I want is to automatically update everything with same user.
Ex. If I have 10mbps, then there are 2 users using the same credentials. I want them to have 5mbps each. even the child queues will be divided depends on how many devices where the user credential was used.
# ********** \\\\\\\\\\ === On Login === ////////// ********** #
:local loginUser $user;
:local a "20000";
:local b "15000"
:local c "5000"
:local devices [/ip hotspot active print count-only where user="$loginUser"];
:set $a ($a/$devices);
:set $b ($b/$devices);
:set $c ($c/$devices);
/queue simple
add max-limit=($a."k/".$a."k") name=($loginUser." - ".$address) parent="Hotspot Connection" target=$address
add limit-at=64k/64k max-limit=($a."k/".$a."k") name=($loginUser." : ".$address." - speedtest") packet-marks=speedtest-pkt parent=($loginUser." - ".$address) priority=2/2 target=""
add limit-at=64k/64k max-limit=($b."k/".$b."k") name=($loginUser." : ".$address." - stream") packet-marks=streaming-pkt parent=($loginUser." - ".$address) target=""
add limit-at=64k/64k max-limit=($b."k/".$b."k") name=($loginUser." : ".$address." - all traffic") packet-marks=all-traffic parent=($loginUser." - ".$address) priority=3/3 target=""
add limit-at=64k/64k max-limit=($c."k/".$c."k") name=($loginUser." : ".$address." - mbl gaming") packet-marks=mobile-gaming-pkt parent=($loginUser." - ".$address) priority=1/1 target=""
add limit-at=64k/64k max-limit=($b."k/".$b."k") name=($loginUser." : ".$address." - pc gaming") packet-marks=pc-gaming-pkt parent=($loginUser." - ".$address) priority=1/2 target=""
:foreach QReset in=[/queue simple find active=$loginUser] do={
	/queue simple
	set $QReset max-limit=($a."k/".$a."k")
# ********** \\\\\\\\\\ === On Logout === ////////// ********** #
/queue simple
remove [find name=($loginUser." - ".$address)]
remove [find name=($loginUser." : ".$address." - speedtest")]
remove [find name=($loginUser." : ".$address." - stream")]
remove [find name=($loginUser." : ".$address." - all traffic")]
remove [find name=($loginUser." : ".$address." - mbl gaming")]
remove [find name=($loginUser." : ".$address." - pc gaming")]
Users browsing this forum: No registered users and 35 guests
