changeip
undefined variables
Thu Aug 16, 2007 12:14 am
In 3.0rc2 how can I determine if a global variable exists or not:
[x@x] > :put [:typeof $anything]
syntax error (line 1 column 16)
In 2.9.x it would return 'nil'... How can I determine if a variable exists or not? I believe this is happening because 3.0 is parsing the variable name for screen validation.
:if ([ :typeof $anything ] = nil ) do={ :global anything 0.0.0.0/0 }
Thx,
Sam
mrz
Re: undefined variables
Thu Aug 16, 2007 10:30 pm
Variable will exist anyway, because in 3.0 all variables must be defined before used in script.
changeip
Thu Aug 16, 2007 11:36 pm
i know that i can define it, however i wish to check if it's already been initialized. I don't want to overwrite the value if it's already there.
mrz
Fri Aug 17, 2007 1:11 pm
if you have defined variable like this:
:global strVar "my string";
next time you do:
:global strVar;
it's value will remain previous, in this case "my tring".
I hope you understand what i mean.
You can check only if variable has no value:
:if ( $strVar = "" ) do= { .... }
changeip
Fri Aug 17, 2007 9:44 pm
ah, i will try that. if i can declare the variable with nothing and have it stay the same that will work. Thank you.
lasa
Tue Feb 02, 2021 11:45 am
I have same question
because
when the router shut down global variables will be clear
so i want to check "does global variables is exist?"
Jotne
Tue Feb 02, 2021 7:19 pm
Its already posted above on how to test for a variable.
Why do not use Splunk to monitor your MikroTik Router(s)? Look at this page in how to set it up.
MikroTik->Splunk
Users browsing this forum: No registered users and 29 guests
