HappyTommi
MAC-PING
Thu Jan 27, 2005 1:08 pm
is it possible to use mac-ping in an script. I can't see the command in the terminal
Tom
edzix
Thu Jan 27, 2005 1:53 pm
yes, it will work like an IP pinging. For example, we will write in logs "Down" when MAC=00:00:B4:C6:7D:C6 is down:
if ([/ping 00:00:B4:C6:7D:C6 count=5]=0) do={:log message= down}
Edgars
HappyTommi
Hmm, it say "invalid IP"
Thu Jan 27, 2005 2:18 pm
I tested this before cause I had the same idear ... I will check again
HappyTommi
Thank you
Thu Jan 27, 2005 2:21 pm
This works. Must be a mistake before in my command
el berto
Re: MAC-PING
Thu Dec 03, 2009 6:51 pm
What's wrong?
Every mac-addres I use (radio or ethernet) is timeout.
ETH1 = 00:0C:42:1C:19:C2
WLAN1 = 00:0C:42:05:E5:50
[admin@Sabotino] > ping 00:0C:42:05:e5:50 count=5
00:0C:42:05:E5:50 ping timeout
5 packets transmitted, 0 packets received, 100% packet loss
[admin@Sabotino] >>
Then, "log message=hello" makes syntax error and no effect when I run it into a script.
fewi
Re: MAC-PING
Thu Dec 03, 2009 7:12 pm
From the manual:
Only neighbour MikroTik RouterOS routers with MAC-ping feature enabled can be 'pinged' by MAC address.
http://www.mikrotik.com/testdocs/ros/2.9/root/ping.php
The syntax for the logging command has changed in the last 4 years:
:log debug "test"
Ehman
Re: MAC-PING
Sat Aug 10, 2013 1:37 am
does not work at all! I can ping a mac using the gui's tool ping, but the command ping does not want to ping a mac-address and neither does the script work for me
janisk
Re: MAC-PING
Mon Aug 12, 2013 1:20 pm
to ping MAC address you have to have other host in the same Ethernet domain as one you are pinging from. Other requirement is that the host has to know what to do with that packet, so it has to have mac-ping server enabled, to be able to answer, and that is only available to devices running RouterOS.
also see up to date manual:
http://wiki.mikrotik.com/wiki/Manual:Tools/Ping
Users browsing this forum: No registered users and 10 guests
