brainy
Scheduler runs twice for no reason
Fri Mar 21, 2008 11:07 am
i have a scheduler that's running twice all the time and i have no idea why.
Start Time: 04:15:00
Interval: 1d 00:00:00
On Event:
interface disable tdsl-768
interface disable tdsl-1000
interface disable sdsl-768
interface enable tdsl-768
interface enable tdsl-1000
interface enable sdsl-768
So it just disable all dsl interfaces and then enable it again (to force a reconnect during night)
According to the logs the scheduler was running at 04:14:59 and again at 04:15:01 ... the "Run Count" increased twice and i absolutley have no idea why!
Any Hint?
It's a ROS 3.6
airstream
Re: Scheduler runs twice for no reason
Tue Sep 02, 2008 2:15 am
I don't mean to raise a thread from the dead but this bug still exists in all versions <=3.13, it affects most of our scheduled scripts across RB's, WRAP's and x86 systems running ROS alike, and as our ROS based network grows it is becoming a problem.
Does anyone have experience here with scheduler running twice seconds apart? is it possible a timezone setting or running NTP client be the cause?, perhaps a fix/workaround for this? any comments would be appreciated.
Keep tryin' its bound to work!!
ROOT@COSMOS> Reality.sys corrupted -- Reboot Universe (Y/N)?
>_
omega-00
Tue Sep 02, 2008 2:00 pm
Just checked one of my scripts that was scheduled to run, no issues here.. running v3.11 on the router
mrz
Tue Sep 02, 2008 8:40 pm
Scripts are running twice only when interval is set to 24h.
vipe
Fri Oct 10, 2008 6:58 am
Scheduler runs twice for no reason is true!
vipe
Fri Oct 10, 2008 7:02 am
how to fix it?????
itsh.net
Fri Oct 10, 2008 11:33 am
I have the same problem with the dual execution in the scheduler in my X86 Server.
I had this problem in the July / August 08 MT Support reported from there I got a reply the problem is known and we want it in the next version fixed.
Until now, it is unfortunately not yet been fixed Perhaps what is being yes in the V3.15
Users browsing this forum: No registered users and 34 guests
