el berto
Upload script on multimple RB's as file
Sun Jun 01, 2008 6:21 pm
I know I can save a script into a file; is there a way to upload a file as script in several routerboards and execute it?
I mean, if I need to execute these commands:
1) IP Route Add gateway=192.168.30.1
2) IP route remove 0
3) ...
4) ...
on all routerboards I have, it would be simple if I can write only a file script to load on all routerboard and execute it.
boyke
Re: Upload script on multimple RB's as file
Sat Jun 07, 2008 1:06 pm
if you use ROS 3.0 or < , use the fetch tool from every RB to download your script, and you can put script to download automatically (put script on /system scheduler), hope help :D
Letni
Sat Jun 07, 2008 6:56 pm
There is an auto execute for ftp'd scripts. Check out the MT newsletter.
http://www.mikrotik.com/download/Mikrotik_no002.pdf
Users browsing this forum: No registered users and 13 guests
